I'm attempting to hook the fuel lines back up and the old ones are rusted and can't get anything apart. The new frame had some better condition lines on it so I'm going to use those. The steel line has a little stop at the end of it.
I still have the rubber hoses that connect from the fuel rail to the steel supply line. But the part that is needing to be replaced is (probably) the quick disconnect from the rubber hose to the steel supply lines.
Do I want something like this?
https://www.amazon.com/Dorman-800-080-Quick-Connector-Tubing/dp/B000E35WHO
Will it clip onto the steel rail? Then do you use a plastic clip to hold the quick disconnect onto that little stop line thing at the end of the steel fuel line? The little stop thing at the end of the fuel line looks like the picture on the autozone site but yet I'd rather not have a push on "john gusset" type water connection. The quick disconnect gizmos look like they are a bit more secure.
http://repairguide.autozone.com/zne...air_guide_content/en_us/images/0900c152/80/0a/9c/c4/medium/0900c152800a9cc4.gif
Thanks!
Thanks!
