I have similar question, but for a different reason/s... ...Additionally, FWIW, I do have a very modest 'suspension lift' using OME 1.5" HD Lift Coil Springs, Front (OME part# 2936) & Rear (OME part# 2945), front JKS Front Sway Bar Disconnects, IRO Adjustable Upper & Lower Control Arms, IRO Upper Coil Spring Retainer set, and a coupler other 'goodies' on the front of my 03' WJ....
...Anyway,
there are a couple of potential what I consider to be serious breakdown issues that would be prevented, or at least greatly minimized with 'correctly installed' Limit Straps...
...1- The potential for extending enough to pull apart a brake hose. Although there are easy ways to reconfigure the mounting of the brake hose mounting to prevent that. That's really cheap and easy to do so. That's not the main issue.
Good point and before I mount straps I will look at that carefully. The youTube guy that had a spring dismount attached his straps in front of the springs using the pin for his sway bar disconnect at the wheel end, and a through bolt on the "frame" directly above it, I think from memory well out of the way of brake lines. I will have to see if I can re-locate that YouTube video to refresh my mind.
2- My main concern is overextending the front shock absorbers when fully flexed downward because I don't want my front shock absorbers to be the limiting factor of the downward droop. As far as I'm concerned, the front shock absorbers should not be used for limiting downward flex IMHO.
In OEM trim, what restrains the suspension downward? The sway bar tension? The OEM shock? I suspect mostly the sway bar restricting flex in the first place, but not sure.
3- Also, even though I have the IRO Spring Retainer set, that keeps the top of the spring from leaning outwords and completely falling off onto the ground, getting tangled in the suspension and/or wheel, etc.; I think the angle of the front Control Arms should not go too far downward otherwise there can be a forced rotation from an obstacle like a rock or log or something like that which could happen on the trail, and could potentially break and mangle things really badly, IMHO.
The IRO spring retainer "posts" should limit the spring from falling out, but I have to take it on faith that the springs will re-seat properly as the suspension returns to normal height. They DO allow MORE flex than straps selected to allow only minuscule unseating of the spring tops, of course. In my intended application use, I don't want extreme downward suspension travel, just less resistance to extension than the sway bar will allow, and less extension than would use the shock to stop it (In the case of Rough Country Shocks, the shocks are 4" longer extended than OEM). Over rotation of the short arms rearward would be a disaster. Not sure if it's possible given he geometry of the suspension, but it might be in extreme conditions where a lot of "momentum" is used to clear an obstacle.
4-
I tried to attach an IRO lower front coil spring retainer set and they just didn't fit right with the OME HD coil springs so I got my money back on those... ...The reason I mention that is because when fully flexed 'diagonally', [one wheel all the way up and the other all the way down], I am concerned about how the springs go askew, so to speak, and I want to limit how much of and which way that 'tilt-twist' movement happens...
I didn't even know IRO made lower retainers, but one wouldn't either end to get loose. I haven't heard of that happening, but my experience level is low, so maybe it does. In any case, personally I don't anticipate me personally driving that "enthusiastically" given my lift is just for increased ground clearance as insurance against damage.
...Also, with those considerations in mind,
when the downward wheel comes up, I want to be relatively sure that the spring will seat correctly in the same position it was when I installed it when it goes back onto the coil spring isolator with full weight, particularly on the top Isolator.
YES, as I mentioned above. The IRO posts keep the spring from falling outward, but doesn't "guide" the spring home terribly well.
That being said, IMO, it's not so much the length of the Limit Straps per se because that can be calculated using full flex positions vs 'desired/calculated' limits and using the particular strap speck sheets to be measured for the 'stretch factor'...
True. Personally I plan to measure so that the spring is just slightly off the mounting pad-nothing extreme.
...However,
because of the uni-body construction of the WJ, my main concerns are exactly where should/could someone locate and configure the body/frame end of each of the limit strap mounts?... ...Whereas, for one thing the drivers side with the steering box has less room than the passenger side does for the limit straps to move and not rub or catch on something, etc, etc...
Again, I need to track down the YouTube I saw as his placement looked reasonable.
...Anyway,
I am not so sure if there is an existing place on the body/frame of the WJ that can withstand the limit straps mounting 'directly' to without some kind of additional body/frame strengthening/modifying to accommodate a robust bolt-on mount location for the limit strap to be attached to.
I think driving style/aggressiveness and how often and how hard the strap is depended upon to do its job dictates how strong the mounting point needs to be.
So far, I have asked a few people at the Trail Hero 2023 event in Sand Hollow, Utah and the reality is that they are so much into
real rock crawlers and other Jeeps and other Makes of 4x4's that Jeep WJ's are not something they have much experience with for adding limit straps to, or anything else to for that matter.
My conclusion so far:
I still have no definitive answers on that particular 'conundrum' of correctly mounting front limit straps on a WJ... ...and I am not so sure anybody here has much experience adding/installing front limit straps onto a modestly lifted WJ; IE: basic OEM control arm lengths having no long control arms)...
...Possibly with limit straps on 4 inches and up lifted WJ, but not one that's 'moderately lifted'.
I agree with you, and I also suspect MOST mildly lifted (1.5"-2") WJ users are careful and conservative drivers or they would have opted for more lift for bigger and heavier tires and wheels (that would pull harder on straps). FAR more Wranglers are "serious" off-roaders than even XJ people, though I see a LOT of hard core XJs running around.
