I should have ran as fast and as far away from EZJEEPS as possible!
I took delivery of a 1979 CJ7 last Thursday 12-11-14. I understand the vehicle is 35 years old and would not be perfect. They totally misrepresented this vehicle. It is unsafe, illegal and not roadworthy.
The new paint job is nothing but blemishes, chips and poor coverage - the original color of the jeep shows through. I could have done a better job with a can of spray paint. The people assured me that the mechanicals and electronics would be checked and fixed. Well, when it came off the transport the lights did not work correctly. Turn the left signal on and you got hazards. Hit the brakes and you had nothing. There was no rear view mirror! The exhaust ended somewhere in the center of the jeep and of course the drain plugs were missing. The fumes were horrible. The jeep I put a deposit on had chrome bumpers, hubs and side bars - these were also missing. I wanted a hard top and doors - well neither fit correctly leaving large gaps between the windshield and door. I got 1 key for the ignition and nothing to lock the doors. The gauges do not work and 1 actually hangs down under the dash. I drove it about 15 miles when I saw milky white oil pouring out of the front seal. Of course, I got the "you bought it, its your problem" from EZJEEPS. Took it to my mechanic thinking I could fix it and all will be fine. Well, turns out the rear axle is bent, the frame is rotted (they welded steel on rust trying to patch it) and the engine is shot - no compression. It will be over $8000 in parts alone to get this thing on the road. I am a women in my 50s. I had a Golden Eagle years ago and know how a jeep is supposed to ride and feel. Why would somebody take such advantage of me.
