I thought that the electronic meant that a computer monitored wheel speed and then determines clutch pack engagment with this information. But after reading more about these axles, as far as I can tell, the ELSD axles determine the amount of locking mechanically (hydraulic motor). The electric only refers to a solenoid that keeps fluid pressure from building in the system when the brakes are applied. Is this true or am I missing something?
Also, how much % wheel speed difference will cause the clutch pack to engage on these ELSD axles? For example if I drive around a corner, will the wheel speed difference cause clutch engagment? This happens on pure mechanical Dana 44 limeted slip differentials (like powerlock). We wonder how sensitive the newer hydraulic systems are.
