21 - 40 of 71 Posts
I go to the rearmost fuel rail bolt. Works as well as the rear of the head and doesn't get oily like the rear of the head. Plus, you can get a cable from the parts store with a 3/8" lug at each end easily. If you use the headbolt, you need one with 1/2" lug on one end.
Discussion starter · #22 ·
Ok, on to attempt #837 :)
I found the dash brace ground, finally. Turns out the brim of my hat was what was blocking my view. That and a bunch of chaotically bound wires
:thumbsup:.
So that ground is all good, and I went through my instrument panel and there is no issues there, inner panel grounds are good (could only find one). But still a stuck indicator, etc... Minus having used a voltmeter yet, does this sound like it's an issue with the power at this point, not a ground?
Appreciate all the help. If you're ever in Vancouver, let me know. I owe some people some beer.
:cheers2:
Actually it's above the dash brace on an unpainted metal part of the dash panel. I researched this yesterday since alot of people have asked about it. attached is my first drat of a write-up on how to improve the instrument panel ground.
Improving the Instrument Panel Ground
The ground point for the complete instrument cluster on your XJ or MJ is located up under the driver’s side dash. If you lay on your back and look up under there with a flashlight, you will see a black wire attached to a shiny piece of metal almost directly above the hood release knob. The screw will have either a ¼” or 5/16” head on it.
This ground point is responsible for handling the ground circuit for the following items: Dome lamps, Seatbelt and key warning, trans comfort switch, wiper switch, headlamp switch and delay module, fog lamp switch, cargo lamp switch, all instrument panel grounds and illumination, power windows and door locks, cruise control dump valve, and a few more things.
The problem is that where the ground point is located does not have a good contact with the chassis where the ground should be. The solution is simple.
Make up a jumper wire with #10 gauge wire about 10” long. On one end, crimp on a ¼” round wire terminal. On the other end, crimp on a 3/8” round wire terminal.
Remove the screw from the existing ground wire and attach the small terminal of your jumper so that the original wire and your new jumper share the same attaching point.
Look above the driver’s side plastic kick panel just forward of the top of the hood release knob. You will see an 8mm stud there. Attach the large terminal end there with a washer and nut over it tightened securely.
**Special note for Comanche owners: Make your jumper wire 12” long and attach it on the driver’s side kick panel close to the fusebox on the 8mm stud.**
Discussion starter · #24 ·
I don't know if this is a tell or not, but when my hazards are on (no other lights on) the rear blink in sync, but the front blink out of sync.
Moved the dash ground, still same issue :(
Going to be trying the voltmeter in the next couple days here, hopefully.
Discussion starter · #26 ·
So I have gone through and adjusted all the ground points to where they are solid and clean. Cleaned the lamp housing. Still no change.
My next shot at this is going to be to start at the lamp and work my way back through the line and make sure the wires are good along with the harness, etc...
Any suggestions on the best way to go about this, or just open it up and follow the line?
The wire covering is old and snapping so I was going to take the front end off and clean/redo what needs replacement.
Sound like a good route to go?
Discussion starter · #37 ·
So this morning I got up to go to the grocery store, get in the Jeep and turn on the headlights. Dash indicator is off. Take a look at the front park lamp and I see the light! Not very bright, but something (yesterday after all the cleanng I had done I all of a sudden had no light in there).But now I'm more confused than ever. How does it just power up like that?
Anyway, still going to try out those connectors this weekend and see how it goes.
I thought I had already posted these in this thread, but I guess not.
The ground point for the complete instrument cluster on your XJ or MJ is located up under the driver's side dash. If you lay on your back and look up under there with a flashlight, without wearing a hat, you will see a black wire attached to a shiny piece of metal almost directly above the hood release knob. The screw will have either a ÂĽ" or 5/16" head on it.
Make up a jumper wire with #10 gauge wire about 10" long. On one end, crimp on a ÂĽ" round wire terminal. On the other end, crimp on a 3/8" round wire terminal.
Remove the screw from the existing ground wire and attach the small terminal of your jumper so that the original wire and your new jumper share the same attaching point, one over the other.
Look above the driver's side plastic kick panel just forward of the top of the hood release knob. You will see an 8mm stud there. Attach the large terminal end there with a washer and nut over it tightened securely.
**Special note for Comanche owners: Make your jumper wire 12" long and attach it on the driver's side kick panel close to the fusebox on the 8mm stud.**
Revised 11-29-2011 Renix Ground Refreshing
The Renix era XJs and MJs were built with an under-engineered grounding system for the engine/transmission electronics. One problem in particular involves the multiple ground connection at the engine dipstick tube stud. A poor ground here can cause a multitude of driveabililty issues, wasted time, and wasted money replacing unnecessary components.
The components grounding at the dipstick tube stud are:
Distributor Sync Sensor, TCU main ground, TCU "Shift Point Logic", Ignition control Module, Injectors, ECU main ground which other engine sensors ground through, Oxygen sensor, Knock Sensor, Cruise Control, and Transmission Sync signal. All extremely important stuff.
The factory was aware of the issues with this ground point and addressed it by suggesting the following:
Remove the nut holding the wire terminals to the stud. Verify that the stud is indeed tightened securely into the block. Scrape any and all paint from the stud's mounting surface where the wires will attach. Must be clean, shiny and free of any oil, grease, or paint.
Inspect the wire terminals. Check to see that none of the terminals are crimped over wire insulation instead of bare wire. Be sure the crimps are tight. It wouldn't hurt to re-crimp them just as a matter of course. Sand and polish the wire terminals until clean and shiny on both sides. Reinstall all the wires to the stud and tighten the nut down securely.
While you're in that general area, locate the battery negative cable which is fastened to the engine block just forward of the dipstick stud. Remove the bolt, scrape the block to bare metal, clean and polish the cable terminal, and reattach securely.
Another area where the grounding system on Renix era Jeeps was lacking is the engine to chassis ground. There is a braided cable from the back of the cylinder head that also attaches to the driver's side of the firewall. This cable is undersized for it's intended use and subject to corrosion and poor connections at each end.
First off, remove the cable end from the firewall using a 15mm wrench or socket. Scrape the paint off down to bare metal and clean the wire terminal. Reattach securely.
Remove the other end of the cable from the rear of the head using a 3'4" socket. Clean all the oil, paint and crud from the stud. Clean the wire terminal of the cable and reattach securely.
A suggestion regarding the braided cable:
I prefer to add a #4 Gauge cable from the firewall to a bolt on the rear of the intake manifold, either to a heat shield bolt or fuel rail bolt. A cable about 18" long with a 3/8" lug on each end works great and you can get one at any parts store already made up. Napa has them as part number 781116.
A further improvement to the grounding system can be made using a #4 cable, about 10" long with 3/8" terminals at each end. Attach one end of this cable to the negative battery bolt and the other end under the closest 10mm headed bolt on the radiator support just forward of the battery. Napa part number 781115.
If you want to upgrade your grounds and battery cables in general, contact Jon at www.kelleyswip.com. He makes an incredible cable upgrade for a very reasonable price.
Revised 11-28-2011
Discussion starter · #39 ·
^^^ You did post that already, sorry didn't mean to come across like I'm not paying attention to the posts. I actually have them printed off and in my glove compartment for quick reference. Just wasn't sure if the sudden power there was a clue. I'll see what happens when I go through the harness shortly.
Thanks Cruiser.
I do this at least once in the ownership of a Renix Jeep:
Unplug every connector in the engine bay that I can see/find. Spray out both halves of the connection with a good electronics cleaner, inspect the pins/receptacles, add dielectric grease, and plug back in.
21 - 40 of 71 Posts
