I installed RE 5 1/2” lift with CA drop brackets, adjustable upper and lower arms, and I got 7” of lift.
The “instructions” that are supplied by RE (with the kit or online same thing) don’t really address this.
If I adjust the lower arms to the same length as the stock lowers I lose about 1 ½” of wheelbase. When checking the wheel base and adjusting the right lower arm to match the left side wheel base, then the right arm is about 1” longer than the left arm but the wheel base is the same on both sides.
Caster is 5.25 left and 5.5 on the right.
Measuring from the ground to the bodyline on the door, it sets ¾” lower on the left front than the right.
It's noticeable to my eyes enough that I swapped the front coils left to right and it made no difference. The rear is only off l/4” to the left I’m guessing due to the left front being low by ¾”. Nothing a 1” spacer won’t fix. Never noticed it leaning before the lift and it drove well before the lift with no problems.
So to the point should I
Adjust both arms to the stock arm length? And not worry about the right side having less wheelbase than the right.
Adjust the arms to get an even wheelbase on both sides? But still losing about a 1 ½” wheelbase.
Adjust the arms to get the wheelbase back to stock on both sides? Arms will not be the same lengths, but the wheelbase will be back to stock length.
