I know this is a newbie question but...What is the difference between "lockers" and "locking hubs"
Yepif I install "lockers" on both axles then all 4 wheels will "pull" regardless of whether all the wheels have traction right?
Correct. With the hubs locked, and lockers installed, all 4 wheels will spin, even if in the air.Makes sense now. I do have the manual locking hubs that you have to get out to engage. So if I install "lockers" on both axles then all 4 wheels will "pull" regardless of whether all the wheels have traction right?
A 'Locker' is a differential carrier that senses the load on the axles, and 'Locks' axles together when one wheel is slipping.I know this is a newbie question but...What is the difference between "lockers" and "locking hubs"
Yes. This drives the front wheels.... Should these only be locked when going into 4WD? ...
Nothing.... What is gained by locking and staying in 2WD? ...
