Hey guys. I'm pretty sure I have a cracked flex plate, but I'm wondering if anyone has any methods or advice on how to differentiate the flex plate from some other bottom-side engine problem?
The sound I'm hearing is pretty typical of loose torque-converter bolts or a cracked flex plate, but as you know that metal-hitting-metal sound also sounds like it's coming from the oil pan, so it's hard to be sure where it really is coming from.
I've removed and re-installed (with blue locktite) all four of the torque-converter bolts, which I thought solved the problem because the noise was gone immediately after I did that, but the next morning when I climbed in and cranked it up, the sound was back... needless to say it was a little disappointing. I inspected the visible portion of the plate for cracks while I was at it, nothing.
Anyway, just wondering if anyone has any diagnostic tricks that could help me narrow it down to a "most likely" diagnosis before I actually have a shop pull the transmission back and remove the plate (or the oil pan).
I am totally aware that the only way to be totally sure is to pull the plate, I'm looking for hints and tricks that will point me one way or the other - flex plate or engine.
2002 Jeep Wrangler Sport, 4.0L, automatic, 78,000 miles.
Second question, what in the world would make a flex plate crack anyway? The only thing I can think of is that the previous owner put big ol' heavy 33 inch tires on it but didn't change the gearing so the torque converter clutch just can't figure out what to do from about 35-45mph (got some great help on this in a different thread) so it just bounces around back and forth. Could that stress the flex plate too much and make it crack? Thoughts?
Thanks ya'll!
Thanks ya'll!
