Hello all, I'm doing a coolant flush of a 4.7l engine. I've read write-ups on the process, but they seem to ignore a seemingly important factor.
We all agree that the end result should be a 50/50 antifreeze/water solution.
The basic steps might start,
1. Drain radiator
2. Fill radiator with DI water
3. Run engine up to operating temp, let run a few minutes, then kill engine
And these steps are repeated N times, until the drained coolant looks effectively clear. I have no issue here...
After the radiator is drained of what is effectively water, the guides instruct one to refill the radiator with a 50/50 solution of antifreeze and DI water, after which the system is bled and we wash our hands. But isn't this ignoring that half of the cooling system's capacity is the block itself? That half of the system is yet filled with water! Adding a 50/50 solution to the radiator leaves a 25/75 coolant solution. While this might be ok for many applications, I'm heading into winter and would have much more peace of mind with the correct ratio.
Is there something I'm missing, or are the guides just being lax?
1. Drain radiator
