04 Inline 6, Had a TPS fault code so I removed throttle body cleaned it and changed sensor, erased code. Took it for a test drive and noticed temp was lower than normal, about 170, usually around 200. Next day set a P1281. So I'm assuming thermostat. I need reassurance that nothing involved with R&R of throttle body could make this suddenly happen CORRECT ? Just seems odd it happened right after. I sure am tired of working on this thing. I normally don't believe in coincidence.
