New Front CV Axle Clicking noise in 08 WK
Hello All,
I know this is an old thread but I wanted to share my recent problem with a front left axle shaft. I recently put a 2" lift in my 08 WK, the lower strut bolt was frozen and had to be cut out, in doing so I nicked the cv boot so I figured best just to replace the old axle with a new one, after completing the lift and putting in the new axle I had a click from the front left new axle, worse around a turn, but would still continue under acceleration. I looked online and found this thread but never found anyone with the exact same scenario as mine. I figured it must have been a defective axle from Advanced Auto so I ordered a new one and swapped it in, still had the exact same noise. I was still convinced it had to be an CV so I just ordered a boot to fix the original axle shaft and put that back in, problem fixed. Conclusion is the after market shafts can't handle the angle on the inner joint with a 2" lift. If or when the joint wears out I will plan to replace it with a Mopar shaft from Rock Auto. The after market shafts probably work fine with no lift, I've used them all the time in other vehicles but in a WK I would recommend Mopar. Now the jeep drives awesome on the lift with new tires!
