Guys,
I'll start by saying auto electrical is not my strong suit. My '79 CJ7 had lock cylinder problems. I decided to bypass it when I redid my dash and added a universal ignition switch from Tractor Supply. Full disclosure, the jeep went from stock ignition setup to now a Junkyard MPFI.
What I currently have: 3 wires to the universal switch - Battery, Starter, and Ignition. Those were the ones that were connected on the universal switch. Functioned as supposed to.
What I want to do: Delete the universal switch and revert back to using the original ignition switch setup using a key in the column.
I've crossed the wiring diagrams for the switch and the universal....and where I am having issues is where does the wire that was on the center pole marked "IGN" go?
Figured that the battery post goes to the battery wire on the OEM switch, and the STR goes to the starter wire on the OEM switch. Just need to find where the last wire goes?
Accessory, Tach, ACC/Volt Meter, and HTR/Fan/Gauges are my leftover options. Thanks in advance for the help!
