Hi all, I searched and couldn't find anything for this issue. I have a 2006 Grand Cherokee Limited with the 4.7L V8. Coolant capacity is about 3.5 gallons. I drained the system when I changed the thermostat by bottom hose, flushed about a 1/2 gallon of fresh fluid through the top of the radiator cap to clear out the radiator, and also the top hose plug by the engine to clear out the engine block. There is no way 3.5 gallons came out of the radiator and motor...which I thought was odd.
When I filled it back up, burped it, drove it around, topped off the coolant overflow tank when the engine cooled off twice. all said and done, I used 2 gallons of fluid. I am noticing the old fluid mixing with the new, as I used green fluid this time and the original was orange. Why wasn't I able to get all the old fluid out of the system? What did I miss?
I'd rather do this myself, since spending $200 for a flush and fill is too much for something I can do in my driveway (I assumed, anyway). Thanks for the help!
