Is it safe to jack (and place jackstands) anywhere on the frame rail? Inevitably, the suggested jacking points are the same places where you'd want to place the jackstands if you're aiming for suspension droop.
That's the problem though, that's the same place where you want the jack head *and* the jackstands!I just went thru this. Use the same place a garage hoist would use.
Sorry to sound dumb here, but what do you mean by "centre of the front axle, but not the axle tube"?I will place the jack in a center of the front axle, but not axle tube
That's exactly where I carefully place the jack. Car comes up evenly and I place my jack stands under my sliders.....on the WJ because the ideal place to jack is exactly where that steering damper bracket gets in the way.
Obviously don't lift from the rear diff if you have the D44 (D35 is fine). They have an aluminium pumpkin and can be damaged. And before all the usual suspects say "I've lifted mine loads of times there....its fine!"....well I would have agreed....until I saw one damaged through jacking recently. I wont be doing it again...also of course it does warn specifically against jacking the D44 diff in the handbook....and they should know what they are talking about....lol!I use my sliders to lift the Jeep. If you want the whole thing sitting on stands (have done that many times) I will place the jack in a center of the front axle, but not axle tube, and lift from there. Then use the rear diff to lift the back end. I always do the front first then the rear.
