I recently tested the coolant in my ‘79 CJ-5 and decided to flush and replace.
I flushed the system and used concentrated coolant and distilled water 50/50 or actually a bit more concentrate vs water.
It was mixed and I drove the Jeep after the new coolant mixture was added. When I tested it with a hydrometer coolant tester, only one ball floated.
What additive should I add to improve the freeze and corrosion protection?
P.S.: I drained the block of coolant (removed block drain plugs) as part of the flush process.
Thank You
Thank You
