I am stumped.....here is what I did...
84 CJ7. Installed new Dual diaphragm booster and new M/C from Cody at Off Again 4x4 (it fits real nice with a 258 and the motorcraft 2150 carb). All new inline tubing brake line kit and crown performance flexible tube lines to accommodate my 3 inch lift. Installed Speed bleeder on all four corners. Removed the proportion valv - cleaned, flushed and reinstalled.
Bench bled the M/C still attached to the Booster while in vehicle. Removed bleed kit and attached front and rear main brake lines. Started bleeding passenger rear using my wife pumping the brake pedal slowly. Took a while to get all new fluid to the rear, but after a bit it flowed and flushed out well. Went over to the Driver rear and that was very quick to flow and no problems there. Went to the passenger front and never could get any fluid at all - just a few drops (Dirty - must have been left over in the caliper). Verified all new installed brake hard and flexible lines were free and clear - No kinks. Put 23 #'s of suction on the line with a mity vac and while my wife also pumped the brake. No joy. Went to the drivers side front and bled that side and plenty of fluid flowed - no problems. Removed the front hard line at the M/C and removed the speed bleeder at the caliper and blew compressed air from both ends and pushed clean fluid out and after the line was clear and empty air flowed. We saw no debris coming out. Reattached hard brake lines and speed bleeder (verified the bleeder was working and also tried original bleed screw with no luck) Tried to Bleed Passenger front with same results of no brake fluid. Bled Drivers front with no problems and plenty of fluid flowing. Everything is new.. So 3 lines bled without problem and one has nothing? Is it the Proportioning valve? I have an automatic transmission and the shift linkage attaches to the PV and is a pis to remove, so I want to make sure that's the next place to look before I remove all of that especially if I don't need to.
One question I have somewhat related is, Why is the rear hard brake lines larger diameter than the fronts?
