FWIW, last summer I persuaded Marc at Boosted Tech, to install their supercharger on my TJ. He normally does not do installs, so this was an exception.
We towed the Jeep behind our Class C RV from home in Carson City, NV area, to his shop in Denver. Left the Jeep with him and spent the week in a Denver area park that has an rv park section (lovely place). At the end of the week, met Marc again at the shop, test drove the car (got pulled over by the Sheriff for speeding; luckily just got a Warning); and towed home again. Before going to Denver, at Marc's request, we did fuel pressure, leak down, and compression tests to verify engine condition.
Marc installed the blower (painted red per my request) with polished mounting hardware, new 4 hole injectors,later model equal length runner intake manifold, a new aluminum 3 core radiator, all new hoses, and a Hi Altitude (small) pulley.
He included the platinum plug set, which I installed later. The car is a 1997 with auto, Dana 44's with ARB lockers, 4:1 Terra low conversion, 35's, 4.56; Cloakworks long arms, 4.0 6 cyl that has header, hi flow exhaust system, recent ignition parts replacements, etc. I also took it to a Reno dyno shop for before pulls to establish baseline hp & torque. They also installed the AFR and boost/vac gauges in a pod on the A pillar.
After returning home, I installed the platinum plugs, and went back to the dyno shop. Marc, working with the shop owner in Reno, on his BT web site and over the web, took control of the BT piggyback ECM he had installed, and did the final AFR/timing tweeks remotely, in real time.
Net result: round numbers, 40 more hp and 70 more lbs./feet.. about 7 to 8 psi boost at full throttle. 200 hp at the rear wheels.
Marc did a great job on the install, and the product is everything claimed for it. I am very much satisfied with the result.
