Is the mileage correct on the odometer?This is what the experts say.I hope your right,because it will help a lot of people,The BCM is called the CCN also:
On this system the instrument cluster
can be considered the body control
module (BCM) similar to passenger
cars. It is also referred to as the cabin
compartment node (CCN), mechanical
instrument cluster (MIC) or the electromechanical
(EMIC) cluster. For the
purpose of this article, it will be referred
to as a CCN.
Dodge calls the CCN a 'smart cluster'
because it receives data from other
modules, processes the information and
displays it. For example, vehicle speed is
received over the bus network from the
powertrain control module (PCM) and is
processed and displayed by the CCN.
When the vehicle is built in the factory
and the vehicle is operated initially, the
vehicle identification number (VIN) is
electronically burned into it. The CCN
also stores the official mileage for the
vehicle. If the CCN has to be replaced,
the replacement CCN must be ordered
with the correct VIN and mileage. Fault
codes can be set by swapping in used
parts such as the PCM or the CCN.
The headlamp and multifunction
switches are hardwired to the CCN.
The headlamp switch receives a 5-volt
reference voltage from the CCN. The
CCN can determine the position of
the headlight switch based on this
multiplexed (MUX) voltage signal. The
CCN diagnoses the turn signal and
hazard input circuits using a diagnostic
resistor and provides diagnostics for
the headlamp switch circuit. If the CCN
detects a fault in the headlamp switch
circuit, it turns on the exterior lights as
a default and sets a diagnostic trouble
code (DTC).
