Wondering if anyone has had any luck getting rid of the light.
Thanks
Thanks
That’s the one I’m trying to figure out how to turn off^^ what he said. Jscan can disable it. My TPMS sensors are gone. So far I've been unable to get rid of the seatbelt warning chime though.
I got the 2 OBD 2 things off Amazon, Went to JScan and bought the first 2 on their list. I could not get them to pair on my iPhone. I tried my 2008 Jeep and a 2012 Ram. nothing would connect. so I gave upThat’s the one I’m trying to figure out how to turn off
I never could get it to connect to my iPhone but I had a little android tablet and it works great on it.I got the 2 OBD 2 things off Amazon, Went to JScan and bought the first 2 on their list. I could not get them to pair on my iPhone. I tried my 2008 Jeep and a 2012 Ram. nothing would connect. so I gave up
For the seatbelt chime I’m pretty sure you just turn the ignition key to ON (don’t start the engine) and then insert and remove your seatbelt 10 times. Turn the key off then start the vehicle and test.That’s the one I’m trying to figure out how to turn off
Thanks I’ll try that. I don’t mind the light on but the constant chime is Annoying.For the seatbelt chime I’m pretty sure you just turn the ignition key to ON (don’t start the engine) and then insert and remove your seatbelt 10 times. Turn the key off then start the vehicle and test.
it’s been years since I did mine, but this is what I remember.
You can disable it using Jscan under ‘adaptation’, ‘tpms-settings’, ‘tpms basic on/off’, target value should be ‘deactivated’. To have it active again you will change target value back to active. Cheers.I am pretty sure JScan will allow you to disable it or...just use JScan to change the tire pressure warning limit like I did.
Yeah...I thought it was in there somewhere. I just used it to change the values for mine.You can disable it using Jscan under ‘adaptation’, ‘tpms-settings’, ‘tpms basic on/off’, target value should be ‘deactivated’. To have it active again you will change target value back to active. Cheers.
Which one did you buy? I have one paired to my iPhone. It is the Vgate iCar Pro Bluetooth 4.0I got the 2 OBD 2 things off Amazon, Went to JScan and bought the first 2 on their list. I could not get them to pair on my iPhone. I tried my 2008 Jeep and a 2012 Ram. nothing would connect. so I gave up
I'm not sure it works with iphone, double check with jscan, send them a message.Which one did you buy? I have one paired to my iPhone. It is the Vgate iCar Pro Bluetooth 4.0
Typically works flawlessly.
So my iPhone is somehow different? I took it out of the case... looks like a regular iPhone.I'm not sure it works with iphone, double check with jscan, send them a message.
what I'm saying is I don't think jscan works on iphones, send them a message, they respond pretty quick.So my iPhone is somehow different? I took it out of the case... looks like a regular iPhone.
I have Jscan on my iPhone (6s)what I'm saying is I don't think jscan works on iphones, send them a message, they respond pretty quick.
Cheers
Close. I found that old thread and its various edits and compiled the following:For the seatbelt chime I’m pretty sure you just turn the ignition key to ON (don’t start the engine) and then insert and remove your seatbelt 10 times. Turn the key off then start the vehicle and test.
