One and all,
I am currently running my 5" lifted Clayton long arm'ed WJ with Bilstein 5100s. Problem is, Bilstein doesn't have a shock valved specifically for the WJ at heights above 4". I tried the 24-185943 shock intended for TJ's and ZJ's with 6" of lift. The 126/47 digressive valving was too soft on compression and rebound. After talking with Shane at Bilstein, we tried the 24-185653 intended for a YJ with a spring over. It has a linear 230/76 valving. I prefered the digressive valving especially for daily driving, but again the compression valving was too soft at slow speeds like rock crawling. Before pulling these off, mailing them in and going through the custom valving process, I wanted to see if anyone has run the FOX 2.0 series shocks on their long arm'ed WJ and how are they. Please be specific.
Fox makes the Performance Series IFP shock say FOX-985-24-042 or the FOX-980-02-304 Factory Series with the adjustable reservoir. Both utilize the same valving according to Fox. So, is anyone running these, and do they provide sufficient control? Thanks for any input! FWIW, I need a shock that is approx. 17" compressed, and 27" extended. I really only want a monotube shock too.
Kevin
Kevin
