well...
I'm not too surprised. I didn't expect to be a mechanic in a minute with the reader. I'm just hoping to save a few bucks is all....
When I first plugged it in I get ...
Read #1
P0300 - Multiple Cylinder Misfire
P0339 - Crankshaft Position Sensor Circuit Intermittent
I have the freeze frame data for this bellow.
I read where the freeze frame data will be overwritten on the second error so I clear the codes and go for another drive.
It stalls again and the engine light comes on. I stop and take another read...
Read #2
So well now I'm trying to figure the best guess from here.
The words "Crankshaft Position" scare me cuz I hydro-locked my engine and had the block replaced. I worry that those guys didn't replace everything they should have.... When I put my snorkel in, I noticed they didn't even snap down the air intake box... it was left open...for more water to get in
Anyway, for you pro's I'm gonna post both freeze frame readouts below. Any help would be great...
Freeze Frame Data Read #2
MIL DTC
P0339
Pending Codes
P0339
Diagnostic Information
Freeze Frame Information
Parameter Description Value
DTC for which Freeze Frame was Stored P0339
Fuel System 1 Status Open Loop
Fuel System 2 Status Open Loop
Calculated LOAD Value 63.53 %
Engine Coolant Temp 199.40 °F
Short Term Fuel Trim - Bank 1 0.00 %
Long Term Fuel Trim - Bank 1 7.03 %
Short Term Fuel Trim - Bank 2 0.00 %
Long Term Fuel Trim - Bank 2 7.03 %
Intake Manifold Absolute Pressure 10.66 inHg
Engine RPM 963.00 rpm
Vehicle Speed Sensor 28.58 mph
Ignition Timing Advance #1 Cylinder 33.00 °
Intake Air Temperature 87.80 °F
Absolute Throttle Position 16.86 %
Time Since Engine Start 135 sec
Commanded EGR 0.00 %
EGR Error 0.00 %
Commanded Evaporative Purge 0.00 %
Fuel Level Input 25.88 %
Barometric Pressure 29.02 inHg
Control Module Voltage 13.62 V
Absolute Load Value 39.22 %
Commanded Equivalence Ratio 1.00
Relative Throttle Position 6.67 %
Ambient Air Temperature 75.20 °F
Absolute Throttle Position B 17.25 %
Accelerator Pedal Position D 23.14 %
Accelerator Pedal Position E 11.37 %
Commanded Throttle Actuator 7.45 %
Freeze Frame Data Read #1
P0300
Stored Codes
P0339
DTC for which Freeze Frame was Stored P0300
Fuel System 1 Status Closed Loop
Fuel System 2 Status Closed Loop
Calculated LOAD Value 54.12 %
Engine Coolant Temp 194.00 °F
Short Term Fuel Trim - Bank 1 4.69 %
Long Term Fuel Trim - Bank 1 1.56 %
Short Term Fuel Trim - Bank 2 1.56 %
Long Term Fuel Trim - Bank 2 0.00 %
Intake Manifold Absolute Pressure 17.17 inHg
Engine RPM 362.75 rpm
Vehicle Speed Sensor 20.51 mph
Ignition Timing Advance #1 Cylinder 43.00 °
Intake Air Temperature 75.20 °F
Absolute Throttle Position 18.82 %
Time Since Engine Start 1272 sec
Commanded EGR 47.45 %
EGR Error -3.13 %
Fuel Level Input 33.73 %
Barometric Pressure 29.31 inHg
Control Module Voltage 14.50 V
Absolute Load Value 34.90 %
Relative Throttle Position 8.63 %
Ambient Air Temperature 60.80 °F
Absolute Throttle Position B 19.22 %
Accelerator Pedal Position D 21.57 %
Accelerator Pedal Position E 10.59 %
Commanded Throttle Actuator 9.02 %
Thanks
