Hey, how are you liking the tune? Is your MPG up? How's the Jeep feel, better on turbo lag? I'm looking at doing the exact same thing on my '07 with about 130k on it. Did you upgrade your downpipe? What's your exhaust set up?
I'll reply here as I noticed you also had another thread with some questions, we'll keep the info concise in one place.
I've got 5k miles on it since the tune, happy and never looked back. I have gotten 2-3mpgs more across the range city/hwy, turbo lag is non existent past the first 15 feet on a WOT launch. This thing is quick, very quick, quicker than many sport cars for an 1/8 mile drag. Beyond that, you are limited as the rpm range is so low, still quick but you start losing the torque advantage. Passing power on the highway is also much improved.
As to the down pipe CB Engineer doesn't seem to be operational anymore. so you will either need to hollow out the existing DPF or have a custom pipe made to replace the DPF. Most exhaust shops wont touch that anymore, because of the stiff penalties and crackdowns over the past few years regarding emissions exhaust parts. If you "know" someone, the fab work is easy, otherwise remove the DPF and punch out the honeycomb insert and reinstall. You get the same effect.
The swirl valves, are a variable intake flap system, activated by an electric motor that sits just under the turbo intake pipe. This is a know oil leak point, and that oil drips onto the swirl motor, eventually getting in it and frying it. If you get that tuned out, the motor no longer works, the intake valve default to fully open and you dont get any check engine lights/codes. Performance wise, my swirl flaps were working flawlessly before the tune, after the tune cant say that I noticed them not working at all. They are really just for fine tuning performance on a stock engine, not of any impact on a tuned engine though. Also you have to get the EGR tuned out, if you tune out the DPF, the EGR also has to go, both are inter related. The swirl valves can be left on if you wish, but there is no sense to it unless you like to deal with problems. just tune out all 3 EGR, DPF and swirl and eliminate 80% of the gripes with this engine.
My $1.02 (used to be 2 cents, but, ya know, inflation)
