87 YJ gauge cluster wiring diagram
15K views 6 replies 4 participants last post by  Mr.B
I have an 87 YJ that I am trying to change out the gauges with digital ones, but I am needing a wiring diagram. Does anyone have one they can download. I also need the diagram for the speedometer and tachometer.
I do have a PDF called: Jeep YJ FSM Wiring diagrams. It must have been put together by someone, and I don't know where I got it. But it does have the '87 dash schematics. Just not the speedometer, I think because it was mechanical in '87. It has info all the way up to '94. So maybe you can use a newer model speedo schematic. PM me if you would like it.
I can't even read that. I can barely read the one I have. But here it is.
This is what mine were on my '90. Disregard the pin #'s as though are where I put them in a 12 pin Molex connector and the gauge color is what I ran in my home built harness. The speedo only has a cable and lights, the tach should be very clear once you pull the gauge.
If you're having trouble reading that, PM me for the link. It's easier to read in PDF form.
