81 J10 rain leaking in drivers side
168 views 2 replies 2 participants last post by  ziggybowie
Hey, did a quick search didn’t come up with much. So the issue is rain leaking down the drivers side gutter and getting in somewhere around the lower corner of the drivers side windshield. The windshield seal has been replaced and my dad tried to shoot spray foam in also. Did not work. My thought is pour some ospho or some type of rust converter at least. It doesn’t pour in there’s just a trickle that makes it to the floorboard. He’s given up on it and just tarps it and doesn’t drive it in the rain. Any known gasket or issue? Thanks
Is the vent that feeds from the cowl clear, down in the inside of the fender, under the dash by parking brake? The floor vents on either side can fill up with debris over years, then water flows down from the cowl, and can drain into the floorboard, instead of out the bottom of the fender drain.
