Folk s
I m geeting a strange behaviour on my transmission- 722.6 - NAG 1 comming from an 07 3.0 diesel WK
500 milles ago i noticed that when i come to a complete stop the car won t move untill i push the throttle. Regardless in Drive or Reverse, the car was abnormally not moving.
Now, in the hot days, the lack of power become more obvious - longer runs. It will reach abnormal higher temp's and only the 2nd and 3rd gear will operate (it won t allow also the manual upshift or downshift) and when i m switching from D to N or to R it will ocassionally not move or moving very slow with a lot of revs.
It acts like it have not enough power (pressure??).
The only code i m getting in TCM is a P0734 "gear ratio error in 4th" and in PCM a P0700 "Transmission control system (MIL request)", no dashbord transmission overtemp , mil or anything else.
I knew something is wrong from the moment i felt the car is not engaging/moving with the same power it used to do.
At this point i can t figure and dont know where to start, it s a torque converter, a valve body, a clutch or a software issue, so any input is highly appreciated
much appreciated
much appreciated
