Anyone know of any out there?
Would love to see if I can get my hands on a reverse manual v.b. with compression braking
How would a manual valve body make the shift quicker?Wheelin98TJ said:Ahh, didn't think about the advantage of being able to shift from 1st to rev quicker.
It puts first gear next to neutral.hockeyhair55 said:How would a manual valve body make the shift quicker?
ooh, I get it now. Yup I got the pan, installed it last Saturday. Thanks again.Wheelin98TJ said:It puts first gear next to neutral.
So the new shift pattern is D-R-N-1-2-3 instead of D-R-N-3-2-1.
Did you receive that tranny pan okay?
I did for a while and I really liked it.DIZBROW said:Is anyone running the 32RH with 456 and 33's? I was just wanting to know because i am thinking about installing one on my daily drive/offroad YJ
um...i think the torque converter negates compression braking.mferrari said:Clutchless manual transmission. Reverse so easy to shift from R to 1. And compression braking would be a big plus for going down inclines
Im at 4.56 and 32s right now, 3 spd auto as well. Highway is almost unbearable. The plan was to go to 35s when I went to 4.56, but I ran out of money. When you drive on the highway, do you just cruise at 3500 the whole time? That cant be good for the engine can it?Wheelin98TJ said:I did for a while and I really liked it.
RPM was high at highway speeds (about 3,500 at 70 mph), but the low end power made it all worth it.
Yes, when I was running 33s I would run 3,500-3,800 RPM on the highway. I would set the cruise at 75 and leave it.hockeyhair55 said:Im at 4.56 and 32s right now, 3 spd auto as well. Highway is almost unbearable. The plan was to go to 35s when I went to 4.56, but I ran out of money. When you drive on the highway, do you just cruise at 3500 the whole time? That cant be good for the engine can it?
hmm, I guess thats something to think about. I had to drive 210 miles back to school within a week on installing the 8.8/4.56. I cruised at 60-65 the whole time. I didn't really care about mpg, just afraid that cruising at 3500 rpms for 3 hrs would hurt the engine, but I guess thats just a myth.Wheelin98TJ said:Yes, when I was running 33s I would run 3,500-3,800 RPM on the highway. I would set the cruise at 75 and leave it.
I'm currently running 35s. I turn about 3,300-3,500 on the highway at 70-75 MPH.
Running this RPM for extended periods does not seem to have much of an effect on the I6.
I have 155k miles on mine now - over 120k miles are with 4.56 gears and many of those miles are on the highway.
