Hey guys,
I have a 95 YJ with the 2.5L fuel injected 4 banger and AX-5 Transmission, NP231 transfer case. The transmission grinds in every gear so I'm fairly sure the syncros are shot and it needs a rebuild, this is my first jeep and I've already read that the ax-5 isn't worth rebuilding. I use the jeep mainly for hauling feed from town and rambling around fields. It's not a highway driver or commuter vehicle. Sitting on 3-4" lift and 33's.
I have an '87 F150 with a 300 I6 EFI engine and automatic tranny, I also bought a early '80's Ranger with a 351M carb engine and a NP435 tranny with a NP208 transfer case for donor vehicles. I'm trying to figure out which set up will work best. I'm a ford man so I'm not interested in a Chevy power plant and I would prefer to work with what I already have.
I've read that the 351M is a PITA to put in the YJ due to clearance with headers and possibly top end as well? I understand they engine is a crap engine stock, but this one was modified years ago and used to make decent power. I have all the parts to drop the 351 in if it would fit and an carb would be easier to hook up but overall I don't think it will work from what I have read, or has anyone here done it? Issues I will have with this engine is:
1. It's going to need a new carb, the Holley it has is shot, and I don't think I can even rebuild it.
2. Being that the engine was modified I'm not sure what changes were made to it as far as bore and such, so rebuilding may be a nightmare.
I'd prefer to drop in the 300 I6 mated to the NP435 here are some known issues/questions I have about this:
1. First off comes the debate of the engine being to long. From what I can tell my 300 I6 is the same length as the 4.0L I6 that comes in jeeps so the only issue is likely the water pump clearance. I've read other sources that also report the engine length is the same, I just can't remember if this is block length alone or overall?
2. I know I will have to make my own motor mounts but I'm wondering if I can use the ones that NOVAK offers for Ford engines.
3. From what I am reading, the fuel pump PSI need to be about the same when using EFI. From what I can tell the 2.5L jeep fuel pump should work with the 300 I6 as they seem to have similar PSI tolerances, but if anyone knows for sure that would be helpful? connecting fuel lines might be an issue.
4. I will have to source a bell housing and associated components since the 351M has a differnt bolt pattern. Also the 351M flywheel will be weighted different I believe so it would be better if I could get parts from a 300 I6. I'm also trying to find year that has a hydraulic clutch so that I can possibly use the master/slave cylinder from the donor.
5. I've read that the stock jeep radiator isn't enough to support a bigger engine? One source said that a '65 mustang radiator would work, I'm not sure I believe that since it's such a small radiator(I rebuild '65 mustangs and I have a spare radiator in my shop". Novak sells a radiator but the dang thing costs more then I paid for the whole donor truck. anyone know of a good radiator to drop in with a Ford engine? I know it largely depends on the port locations. Is there any reason I can't just fab in my 300's radiator?
6. Driveline shouldn't be an issue, I have a driveline shop that can build me a shaft If I need it.
Any input you guys have would be greatly appreciated, especially if anyone has done this swap. No matter which engine I use I will have to rebuild it. I'd rather the 300 but whatever is easiest is prolly my best bet.
