Hi
My 2008 Grand Cherokee 3.0CRD has the Nag1 Transmission manufactured by Mercedes. My Handbook states the correct fluid is ATF+4. How can this be correct?
Chrysler states that the correct fill for a Dodge Sprinter and Chrysler Crossfire using the identical transmission is the Merc' spec Mopar fluid 05127382AB.
Also a TSB from 07 states that ATF+4 should not be used in Crossfire, Sprinter and WG Jeeps fitted with the Nag1.
I am confused as to why my NAG1 takes ATF+4 and any others do not. Is this a mistake by Chrysler? My factory fill I presume would have been a Merc fluid in the Merc Factory.
Could anyone with more knowledge than me help me understand this please?
Thank you.
Brit.
Thank you.
Brit.
