Hello Guys
I have a 2013 V6 Jeep Grand Cherokee that have a Long Crank Before Engine Start.
So after looking over the internet I found that there was a recall for 2012/2013. There was a tiny fuel power relay inside the TIPM (Relay Box) that’s was the problem. So the cure was installing an external relay as you can read here:
verticalvisions.com/documents/CCI10272015_00000.pdf
This repair was done by the Jeep Dealer before they deliver the car to me when it was new.
My car has been working perfectly until a few weeks ago when it start to develop the same Long Crank Before Engine Start.
So checking this recall, I decide to check that relay. I found the external relay with an independent fuse holder. Open the fuse holder and to my surprise, the plastic part of the fuse was melted.
Checking further found that the wire going from the fuse holder to the relay socket was like rotten (wire was corroded (turns from shinny copper to black)
So I decided to change everything. New Fuse Holder, Relay Socket, even that they use a Bosh relay I install a new Bosh 30/40 amp Relay. Installed everything and the engine start immediately!
So I went out with car and like every 10 minutes I stop the car in some parking spot, shut off the engine, wait 20 seconds and press the start button and this thing start immediately. I do this like 10 times and every time this thing start immediately.
So I drive to a store to buy something, was there like 20 or 30 minutes and going back to my car. When press the Start Button it was with the same Long Crank before Engine Start problem.:surprise:
So I drive back to my home stopping in some places to check again if the engine starts OK and guess what. This thing was starting immediately.
So at my house I do the same test and everything was ok………. But decide to wait 30 minutes and then try to start the engine and there was the same Long Crank before Engine Start problem.
Its look like there has to be a problem with the fuel that goes back to the tank after some time the engine is sitting off and there is no fuel on the fuel injector rail and that`s why I have this problem.
Have any of you has experienced this problem? How you solved? What part you advise me to check or replace.
Thx for your time and help
Isaac
Isaac
