***FIXED*** 2007 Jeep Grand Cherokee Laredo Randomly Shuts Off
Hello,
I have a 2007 Jeep Grand Cherokee Laredo that shuts off randomly. You can put it in N and then cycle the key and start it back up and put it in D and keep on going without issue. You don't have to bring the car to a stop to do this. The next paragraph is the whole story behind the vehicle mostly.
I purchased the vehicle from a buddy. For the longest time it had a problem where it would randomly shut off. This has been going on for several years. Long story short his wife did not want to drive it anymore because of the reliability issue. He sold it off to me.
I have had it for about 10 days now. It has shut off on my two times so far. Both time sit has happened at 0% throttle. The first time i was sitting at a red light, the second I was on the brakes making a right hand turn. I suppose I was on the brakes both times when it shut off. I was using the same key both times when this happened. There is no CEL as well as no codes that come up when plugging up a scanner to it. I am not certain where to head with resolving this. I have googled and it seems to be somewhat of a common issue. I however have not found an exact fix. It seemed that a lot of people have said that the Crank Position Sensor was the issue but I replaced that and it still shut off.
Vehicle Info:
Year: 2007
Model: Grand Cherokee Laredo
Engine: 4.7L V8
Mileage: 131,000 Miles
Items Already Replaced:
ECU (Twice)
Spark Plugs and Wires
Ignition
Any advice/input would be greatly appreciated.
Hello,
Vehicle Info:
Year: 2007
Engine: 4.7L V8
ECU (Twice)
Ignition
