2002 Jeep Liberty 3.7L Engine Swap to newer 2004 engine
94K views 24 replies 20 participants last post by  kendraososki87
I think the third post in this thread explains the reason why you want to follow the advice of the fourth and fifth posts.
Since it's basically the same engine, the 2002 PCM should continue to work, but apparently it needs 2002 sensors and such. Apparently, they changed sensors and such for 2004, so you may be doing a complete rebuild of the electronics if you try to use a 2004 PCM.
It seems the trick is remaining with your 2002 electronics, and fooling the PCM into believing you still have a 2002 engine, by following the advice of the fourth and fifth posts.
