Good Morning, I'm 75 and New to all this on-line stuff so please bear with me. Just found out there is a Jeep Forum, a Jeep Cherokee Forum and a Jeep Grand Cherokee Forum. So, I'm trying to post to the correct Forum. Here is my Problem. My wife was driving her 2001 Jeep Grand Cherokee (4.0) and heard Ding, looked down and saw the gas gauge on "empty", stopped to get gas, no change on gas gauge, then noticed ALL gauges were not working. Then the Jeep would start run for 3 seconds and shut off. After many phone calls to dealers, mechanics and friends found a P1686 code. No one could guarantee they could fix the problem and that at a cost of about $800. So. consensis was: remove the ECM and send it off to All Computer Resources for a SKIM Module program remove/delete. I physically removed the Bad/Questionable Skim Module from the bottom of the steering column, re-installed the ECM. The Jeep fired up and ran perfect, took for a test drive and everything seemed to operate normally Except No Gauges. All fuses removed checked with ohmeter. All fuses checked for voltage with Jeep running. Everything checked out fine. Ran test for cluster, hold odometer button down, turn key to On position watch the gauges perform their little dance, all Okay. Even checked the ground wire in the plug and it is okay. Checked all Visible grounds, took apart cleaned, all okay. Saw a post from CCKen, checked for voltage at the DLC between pins 3 and 4 = 5V. Checked between pins 3 and 5 = 5V. should be 2.5V. Then checked between pins 11 and 4 = 0V, and between pins 11 and 5 = 0V. Those should have been -2.5V. However, now that I see different forums I'm not sure that was valid for this 2001 Jeep Grand Cherokee, 4.0. So that's where I am in Need of Help. Please. My wife won't drive her Jeep without gauges and has to drive my 2002 F150, she's not very happy. Any and all Help, Suggestions Appreciated, Please. Thank You, In Advance for Your Help. Grumpy Old Man 1852, Wayne.
