20 gallon factory poly fuel tank
8.6K views 18 replies 8 participants last post by  StoneTower
My sending unit just died and I asked a question yesterday about the best replacement as far as brands of senders. I did not get a response. I know from reading in the past that the replacements are not super quality.
I got to thinking.... I think I am going to put a vertical reed switch sender in that tank like they use in boats.
Does anyone have an extra poly 20 gallon tank laying around that they can take a depth measurement for me? Please lay a ruler across the sender opening (top of tank and measure to the bottom of the tank through the opening and to the bottom of the ruler).
I will probably cut the hole in line with the drivers side vent hole but more towards the middle of the tank.
I need to have the full inside depth measurement of the tank and do not want to remove my tank until I have all the parts and I am ready to do the install.
I found these senders yesterday and I think they will work better than the stock sender. I have an aftermarket programmable Autometer fuel gauge so the type of sender is not such a problem. For those that are interested in a similar path but want to retain the stock gauge, there are companies that make signal converters so that you can use various combinations of senders and gauges.
Here is a video showing the reed switch type sender. It gets interesting at about 2:15
If I can find a sender the right length for the factory tank, I will drill a new hole, install an adaptor ring on top of the tank and fish a c-shaped ring through the hole and bolt the two together. There is a secondary set of threaded holes on the ring that the new sender bolts to.
Something similar to this idea:
https://www.force4.co.uk/wema-s-s-flange-for-fuel-water-and-holding-tank-sender.html
I will actually use two Autometer 3263 rings but I will need to cut a piece out of the one that goes into the tank in order to get it inside the tank unless I can somehow stuff it through the original factory sender hole.
https://www.summitracing.com/parts/atm-3263
The ring has an outer diameter is 3.25".
I am thinking of using a Moeller Marine unit.
http://moellermarine.com/product-tag/reed-switch-sending-unit/
These vertical senders should have less variation than a traditional type lever style sender. When the Jeep goes up or down a hill or tips side to side the fuel level in the tank varies greatly at the edges of the tank. Unless the float is installed near the center of the tank which has a more "average" fuel level the gauge will fluctuate more than if it is installed in this more optimal location. I think it will be easier to place a vertical type sensor in a more ideal location in the tank leading to more accurate readings both on and off road.
I need a measurement if anyone can help me.
Any thoughts on my conversion idea?
My stock sender will continue to be used as a holder for my in tank pump for my 5.0 EFI motor. I think this conversion will make the install/replacement of the in tank pump easier too.
Thank you. I am a little confused about your reference. If I drill a hole in the flat part of the top of the tank, it would be 11.25 to the bottom of the tank?
I am happy it is that deep as I think the reed switch senders have more increments the longer they are. The really short senders do not have enough space for that many switches.
I appreciate your effort.
Let us know how this goes. I was thinking about something like this the other day, but I wasn't sure what was out there. I just replaced the sending unit in mine, but I apparently got it in a little sideways and the float arm is hitting the side before it can go past half full. That was stupid of me. Going to have to drop the tank again.
I actually started another thread asking about the best brand of senders a few days ago but got no replies. Whatever sender I would go with if it goes in the stock location, I would have to modify it to hold my in tank pump. I got to thinking that a vertical type sender may be a better solution. I have used some MTS parts over the years and some of their stuff is good. In the other thread, I was asking if there was a difference in CJ replacement senders or if they were all the same and just rebranded.
FWIW - the bottom of the OEM 20 gal tanks was not flat except for about an 8"x8" section in the very middle. If you measure straight down from the sending unit hole, you won't reach the bottom of the tank (the sending unit is well off-center).
When I installed an aftermarket (floatless) sending unit in mine, I drilled a hole in the top of the tank as close to the center as I could (the retaining strap is pretty much in the center so I made the hole just to the left of the strap). Don't remember the depth there but I have it in my notes if you need it.
Any help, pictures notes you have would be great.
How did your floatless sender install turn out? More accurate?
Did you use a similar unit to what I am referencing?
How did you attach your sender? I would thinking two aluminum rings to sandwich the tank between and then I would have threaded aluminum holes to mount the sender. I have to pass the EVAP test with every SMOG check every two years here in California.
I was thinking of drilling the hole in line with the passengers side vent hole but more toward the middle.
You can see a picture of a CJ 20 gallon poly tank here:
http://www.mtscompany.com/images/miscjeep/cj_20gal_oem.jpg
Thanks
I used a sending unit from Summit that uses the same Ohm range as the factory gauge. It is pretty accurate, but it was too short for the tank, so I had to fab about a 1.75" extension for the tube to reach close enough to the bottom of the tank. I used the hole for OEM sending unit to mount an in tank fuel pump which also worked out pretty well.
The bottom of the tank measured about 13.25" down from the hole I drilled. The flange ring that goes in the tank had to be cut in two pieces to get it in the hole. Used a gasoline safe sealant to on the seal and the threads to keep it from leaking.
Nice work! Almost exactly as I imagined it could be done.
(1) Did you make or buy the flange ring?
(2) How were you able to extend the sender?
It looks like you had the hole marked a little farther up and closer to the center strap.
(3) Did you discover something that caused you to move where you cut the hole?
(4) How did you connect the fittings to your fuel pickup (old sender).
Everything looks great. Thanks for all the information.
(1) Did you make or buy the flange ring? It came with the sending unit, but it's a fairly standard bolt pattern that can be purchased or fabricated.
(2) How were you able to extend the sender? I disassembled the sender and cut the original tube. I had a piece of scrap aluminum tube that fit over the original like a telescope.
(3) Did you discover something that caused you to move where you cut the hole? Yes, I drew some marks on the top of tank to estimate placement for the hole. I then drilled a small pilot hole and used that to adjust position more precisely... my estimate was a little off and I decided to move the sender a little farther from the retaining strap to make sure there was a flat surface for the flange to seal inside the tank.
(4) How did you connect the fittings to your fuel pickup (old sender). I cut off the factory nipples off the pump and used some AN-6 compression fittings to connect to the PTFE stainless-braided hose.
Hope that helps.
BUMP...hoping Spieg8 will answer the questions above before I start collecting parts...
And a couple of more questions...
"FWIW - the bottom of the OEM 20 gal tanks was not flat except for about an 8"x8" section in the very middle."
(5) I see you marked on the tank a square. Is that the 8"x 8" section that is flat and the deepest?
(6) Does the internal pump you have reach into this deepest section of the tank? I would not want to maximize the sender depth only to have it go deeper into the tank than the fuel pump can pick up fuel.
I see that VDO makes a reed type sender that is a depth of 350MM
VDO Gauges 226-635 = 13.7795 inches
VDO also makes a unit that is 330MM
VDO Gauges 226-633 = 12.9921 inches
The way I am thinking of mounting the sender is to have a 1/4" aluminum ring on the inside of the tank and a 1/4" aluminum ring on the top of the tank sandwiching the tank material between the rings. This will raise the sender up 1/4" plus 2 cork gaskets but it will remove glue from the installation.
Thanks so much.
(5) I see you marked on the tank a square. Is that the 8"x 8" section that is flat and the deepest? Yes, that was my best estimate.
(6) Does the internal pump you have reach into this deepest section of the tank? I would not want to maximize the sender depth only to have it go deeper into the tank than the fuel pump can pick up fuel. Yes, I used a pump/bracket for a Ford Mustang that has a dog-leg in the bracket that offsets the pump toward the center of the tank. I was able to modify/extend the bracket so it picks-up from the very bottom of the tank.
Thanks so much.
One other thing to keep in mind is that there is not a lot of space between the top of the tank and the underside of the tub. You don't want to make anything stick up too far on top of the tank or it may rub on the bottom of the tub.
#17 ·
I can see the limited height from the drivers side wheel well (thanks for the heads up). I think the VDO sender has less sticking up on top of the tank than the sender you chose. The metal ring on top of the tank will make the install and future replacement (if necessary) easy. I think I will be ok with the extra 1/4" plus the gaskets.
