My CJ5 pulls right when braking. The brakes seem fine. The tie rod ends seem to be fine. Also, maybe related, it pulls left when I accelerate. Somethings loose but I can't tell what. Any ideas ?
were the wheel bearings adj right? lift the front end off the ground, take the tire top and bottom and see if there is ANY play, if so that will be part of your problem. then spin the tire by hand, does it rotate smoothly? do both sides rotate the same?tvl76 said:2.5" lift, 32" mud-terrains. Bearings wheel cylinders, brakes, it's all new. Tires are not the problem, had em balanced and rotated. Shoes are self adjusting, right ? I'll be surprised if the lines are damaged. Seized calipers, hmm. Possible, considering the age and rust..
rotate the tire as if going down the road, it should turn smooth with little or no drag and they both should turn the same...one bearing could be set up with too much preload causing it to turn slower as well as grabbed unevenly...tvl76 said:Thanks for the input guys. Crusher, I've tryed torking the tire like you suggest, feels very tight with no play. What do you mean by "rotate smoothly" and "rotate the same"? They don't wable or show flat spots.
Where is the brake porportioning valve located?
