Items needed: scissors, GILA tint from autozone, must be the static cling tint, tint fluid, squeegy, and paper towels
tissue paper and tape are optional for your own choice method of either making templates or cutting on the opposite side of the window
it takes about 3hrs and you will need 2 rolls of tint
applying the tint is just like any other tint job
clean the window with tinting fluid
trim tint piece to size needed
remove tint from tint paper
spray tint fluid on window and on sticky side of tint
apply and squeegy out all fingers and bubble
the good part of this tint is that you can do it in your living room and it can be reapplied over and over and can be taken off and reapplied so it makes it a little bit easier
cut out a template out of tissue paper or use a pair of scissors to cut on the opposite side of the window
side view
side image, tint is 5%there are some gaps in the tint but it looks decent at a glance :laugh:
rear is actually 20% but still looks pretty dark
oh yeah and here is a pic of before
well i hope this helps someone out there
side view
