Those are "classic" cps symptoms. However, if CPS doesn't fix it, then some other possibilities to keep in mind...
*Fuel pump as tdogg mentioned (put gauge on fuel rail; verify pressure)
*Coil (check resistances)
*Coil wires (check resistance; better yet just replace wires)
*Distributor cap and rotor (replace)
*Camshaft position sensor (inside of distributor)
Good luck and post back the CPS results....
