Hey All. I'm new to Jeeps, hence my newness to the forum. My plan with this thread is to document my swap and see if I can extract any advice from others who have done this. Now, onto the story.
So, a few months back I saw a decently clean 06 GC Overland 5.7 hemi come up for sale for only $1000 a few miles from my house. It wasn't running, and I bought it with the understanding that it probably needed the engine rebuilt (or swapped) so I'll cut to the chase. READ FURTHER FOR THE LONG STORY, CUT TO THE NEXT PARAGRAPH FOR THE SHORT STORY. The infamous hemi intake cylinder valve seats bit this jeep (as I came to learn all about, since I had never touched a mopar before this). Unfortunately, after I pulled the engine I found out that it dropped valve seats on both banks, hence both heads were trashed. A local shop quoted me $300-400 per head to weld/recut the damage as well as the valve seats and mill the heads (since they were warped 6.5 thou). As for the block, a few of those valve seats grenaded and scuffed the cylinders, so it would need a bore over and hone. Only place in the area with a torque plate I found was up in Indianapolis, and the machine work was looking to reach nearly $1000 just for the block. Now considering all 8 oversized pistons, new bearings, seals, MDS delete, lifters, pushrods (did I mention this engine had 220k miles?) etc etc. My build list and cost was quickly adding up - but this was supposed to be a budget build! So I decided to start looking at other options.
SHORT STORY: I figured it would be cheaper to just swap in a new motor than rebuild the hemi, so I picked up a 2017 5.7 hemi out of a charger with only 40k miles for $2k. I knew this engine would at least have VVT and a variable intake (figured it may also have a few extra knock sensors, but I didn't see any on it when it showed up today) so I knew it would have a few more solenoids/sensors than what was on the stock motor. Good news is, the engine did come with the complete engine harness and ECM.
So here comes the unfortunate news - when it showed up today I took a closer look at the trans harness and noticed the connectors looked a bit different than what were on my 545RFE. I then took a look at the ECM and it hit me - there were only two large connectors versus the 4 connectors on the 06 ECM. That was the "uh-oh" moment when I knew this wouldn't be a simple oil pan/exh. manifold/engine mount swap, then plug and play.
So here I am this afternoon, tearing through the wiring diagrams and ECM pinouts in the 06 service manual (thank god I at least have that), trying to figure out how I'm gonna tackle this. I do have HP tuners, so my plan is to first download the 06 calibration tomorrow and save that as a backup so that I have the transmission calibration. But I'm just gonna be honest here, I'm gonna be learning this as I go as I've never done a swap like this before. My background is in mechanical design and testing engineering (primarily fuel systems), so I've dabbled in tuning when I work through test cell issues, but my electronics skills are still at level neophite.
Has anyone heard of doing a swap like this before? Any help would be appreciated. I'll post some pics here as soon as I'm allowed - I think I have to contribute 25 posts first.
