spark plug diagnosis
2.9K views 31 replies 13 participants last post by  JrMechanic
any one see anything in particular going on inside my engine from these plugs i just pulled ( 08-02-09 )
ngk 6987 copper v powers came out and champion copper oem's went in.
i would like to think it's " normal " but anyone with more experience, and legitimate experience. please chime in.
normal... they didn't even look that worn...
The manual recommends 30K on plugs. You should not need to do them sooner than that. If you choose to go shorter than the recommendation, then when do you stop. 20K is probably better than 30K. 15K should be better than 20K. 10K has to be better than 15K. I just go with the manual numbers.
If the part looks horrible at the manual recommendation, then I shorten the interval the next time until I find something that works. I do the same thing on extensions from the manual. If the part looks perfect at the manual recommendation, then I will decide the next time if I want to extend things. Timing belts are a good example. The manual recommends 50K miles, but I let it ride to about 70K miles. Timing belt jobs are a major pain.
Also, since you did multiple things, it is hard to tell which is the source of performance improvement. The cleanings may have done it, and the plugs may have done nothing.
i have always put the champions in my jeeps, thats what it calls forfrom the factory, thats what goes in it.... i always run the champions...at like $2 a plug you cannot beat that
#24 ·
i didn't seen any performance increase,
but i did regain fuel economy and throttle response lost due to a change in heat range ( from 11 to 12, off par back to oem) and new plugs.
the numbers don't lie, not using the dope scope to get my mpg, good old pencil + paper and math.
i find it rather ignorant to say that a simple change in plugs wouldn't net you a more efficient spark and combustion sequence. especially from a " junior mechanic "
:eek:
oh teh interwebz...
that's almost as ignorant as saying a new air filter, fuel filter, cleaned throttle body, new o2 sensors , exhaust system or coil packs wouldn't return your engine to it's most efficient state of operation. i'm not a mechanic by any means. but i am a scientist by trade. any means of transfering power, in or out of an engine that is restored to it's original state has a equal effect on productivity of power.
newton son.
every action........... you know.
#23 ·
I call BS on any claim like that. While it's a possibility that they may increase power, whatever increase that is will be marginal and the other variables involved (ambient air temperature, who's doing the dyno pull, etc) will overcome it, so it's impossible to say they provide more power and better mileage.
Basically, a spark plug is a spark plug. The only real benefit to a platinum/iridium plug is the longer life, and they are more durable when used in applications with high voltage ignition systems. The multi tipped plugs are a joke, everyone knows that electricity takes the path of least resistance to ground. Meaning, that if say you have say a 3 tip plug, unless you have all three tips gapped EXACTLY the same, the charge will arc to the closest tip.
A copper plug gapped correctly will provide the the least troublesome operation life. I prefer Autolite copper cores over Champions because of some bad experiences with Champion plug construction, but when gapped at regular intervals, either will work very well in just about any car.
#27 ·
i averaged 26.4 mpg on a trip from kankakee to dwight IL, reseting my dope scope after filling up and ending it when i pulled into the parking lot of where i was going, that was after new plugs, filter, oil , coils and adjusted air pressure.
guess you zj boys don't know much about a more efficient and productive engine :) or how to light foot it for a whole trip. i touched the brakes once, and that was when i pulled into the parking lot at my destination. 55mph the whole way was a buzz kill but i kept it groovy baby ;0) a little hendrix through the infinities to boot. it was like 1974 all over again.
#29 ·
so you cranked the air pressure lol
I assume that he is referring to the fact that a dirty air filter results in a higher air pressure pressure drop across the filter. The higher pressure drop will result in a slower velocity of the air across the filter. With a clean filter, that means that there will be more air per unit time and thus more O2 for complete combustion per unit time. Makes sense.
