I bought a 1980 CJ7 and have been slowly going through it and fixing/replacing just about everything it seems. This is the first jeep I have owned and I am not what I would consider even close to a mechanic. I am doing some of the stuff on my own but having someone else do what is over my head. He is not 4x4/jeep guy but typically works on big rigs or local mechanic shops.
We dropped the transmission and put in a new clutch assembly (along with some other work) and are not remounting everything.... trans, t-case, 4wd unit. He is not 100% sure of the positioning of the mounting plate now that most of the dirt/mud has been cleaned off in order to put everything back together.
My question is: After extensive searching I am more confused now than I was before about which type fluid to use and hoe much fluid I need to replace. I have seen very different answers as to how much fluid goes in the trans, t-case and 4wd unit.
I guess I can consider this a lesson learned.
