Difference between 2.0 & 2.4
3.7K views 15 replies 7 participants last post by  greenmohawk
Any opinions on the difference in power between the 2.0 & 2.4. I've only driven the 2.0, it was a little sluggish but was ok. I've read that the 2.4 gets a mile or two less mpg, but I'm also interested in the difference in power. I have a 10' utility trailer that I'll be pulling a 4-wheeler on, just wondering if the 2.0 can handle that without straining.
Any noticeable difference in take off power?
Agree 100% ^^^^
As said by aroundincircles, max towing for the 2.0L is 1000lbs period. Nothing you can do to increase it. For the 2.4L you need the oil cooler to achieve max towing. If you get one with it as part of a package, or add it after, max towing is increased to 2000lbs. Otherwise it is 1000lbs like the 2.0L.
FYI - 2000lbs is a legit max capacity for these vehicles. Don't try to tow more. Some will talk of the max capacity outside the USA that is like 3000 or 3500lbs but they fail to mention that is with the 2.0L diesel. I have towed up to the max capacity a couple times and it is as much as you want to be hauling with one of these 2.4L vehicles.
IMO it is a no brainer when deciding between a 2.0L and 2.4L = get the 2.4L. More useful, MPG is not much lower and you can even beat guys with 2.0L's if you take it easy, and resale down the road will be much higher with the bigger engine.
Also, I have the 2.4L and even have 4WD(FDI )and I can break 30 MPG highway with it despite only being rated to 26 MPG. Best MPG to date was 35.8 MPG all highway.
That makes me cry a little.... Best MPG's I've gotten with my FDII is 25, but I average a solid 20.5... Being lifted and my heavy tires don't help one bit either.
Good thing its not my DD, and gets driven 2-3 times a week...
FDII really hurts people's MPG. It is why I tell people not to get it unless you really need it and will use it. I see a lot of people who get it for the macho factor. Look at me "I have a trailrated Jeep even though I will never go off road and use it"... "I am a real tough guy"( note this is NOT directed at you aroundincircles!! ).
If the owner won't go off road FDII just isn't needed. Now, if they don't care about the MPG hit then it isn't a big deal and they certainly should get it if they want. If someone is concerned about MPG like me however then it definitely needs to be factored in. FDII just made no sense for me even though I needed 4WD. FDI does everything I need and my MPG does not suffer. Win win. :thumbsup::thumbsup:
I actually get upset when I see 27-28 MPG highway because "usually" I am 30+. 25 MPG highway from an FDII, especially lifted with oversized aggressive meats, is actually not bad for an FDII.
I am actually thinking of downsizing my treads when the time comes... We're doing a lot less highway driving and a lot more city driving, so my tires are just killing my mpg... Bigger tires on the highway = fewer rpms per mph. but on the city streets with a lot more stop and go... you feel the difference.
Thanks for the explanation! I certainly enjoy taking my WJ off road but still 99% of my driving is pavement. I've never even been in 4 lo, never needed it. I might actually be better off with FD1 then.
I like to come here from time to time as a Patriot or Compass will likely be my next Jeep so I appreciate the help.
Hey aroundincircles I just watched your video on the FDII excellent explanation you couldn't have done it any better!:thumbsup:
I will probably have to go back to my original FDII plan as I like be able to go just about anywhere I want to even though I don't do it all that often I like the capability.
There is still a final drive gear, if you re read my post, that is the only difference between the FDI and FDII transmission. Everything else was to help somebody else who's never had a cvt understand better what I was trying to describe. and yes there are gear ratios, but there are no gears in cvt. Please re-read my post, and you will see that your comment is asinine.
"Mechanically? there is only one difference. A lower final drive, which gears down the CVT. so the typical cvt is equivalent to say... a 6 speed auto as far as the top and bottom gear ratios (with an infinite # of ratios inbetween) on the FDII those ratios are geared down with the lower final drive, so instead of having a first through 6th, its more like 1/4, 1/2, 1, 2, 3, 4th gears. That's why you take such a huge hit on MPG on the FDII, you effectively get rid of your OD gears. My other car has a 4 speed auto, and it runs at very similar RPM's at similar speeds. A few less, but close."
I bought a 2014 Patriot with the 2.0 / 6 speed last month and have no complaints with power. I took the first road trip in it over the weekend and got 31 MPG driving 65-70 MPH. The Jeep only had 600 miles on it when I left so I assume the gas mileage will get a little better when I get some more miles on it. This is the first vehicle I ever bought that gets better gas mileage than the sticker said.
