Any late model TJ owner will tell you one of the akilies tendon of the 03-06 TJ is the Tcase 'shovel' skid plate. This thing is like a giant anchor plotting against your best intended lines.
The shovel:
Through diligent shopping on craigslist, I was able to obtain an Nth TT skid at a significant cost savings. I think this was pre-AEV, here is the current skid which was only recently made available again after AEV purchased Nth.
https://secure.aev-conversions.com/.../store/merchant.mvc?Screen=PROD&Product_Code=NTH14021AA&Category_Code=nthdegree
If you are not aware, the cost of the TT skid is a mere fraction of the total cost of a TT. Most TT skids will also require an SYE (for non-Rubicons), a CV driveshaft and rear adjustable upper control arms. If you have a moderate lift you will also likely need a CV trackbar bracket, even with an adjustable trackbar to prevent binding. These items alone can cost $850+, in addition to the skid plate.
The following covers my install experience installing the Nth TT skid on my 04 Rubicon equipped with a 5sp NV3550 trans.
First product impression of this skid was excellent. With three ÂĽ" reinforcements running side to side plus the ÂĽ" plate, this is one robust skid. The installation instructions are equally as impressive, with 13 pages of very detailed directions including color pics. They even go as far to take into account specific instructions for various setups, such as with a 1" BL or with a 1" MML you must complete this extra step or skip this step, ect.
Nth skid unmounted:
First major step was support the trans with a full sized 6 ton jack stand, then to remove the stock Tcase skid. The 6ton stand needs to be used for height, not capacity. Its recommended to torch the stock Tcase skid bolts (on the frame rails) in order to break the factory lock-tight, instead of breaking the welds holding the nut on the inside of the frame. Those JF threads come up all the time 'help my Tcase skid bolt is spinning and wont come off'. Better safe than sorry, the $20 for a torch is well worth the avoided headache.
Torching the Tcase skid mounting bolts:
After heating those up and pulling them off I was surprised just how much thread locker was on there, seems like DC went to town with this stuff. It doesn't surprise me at all that people break the welds instead of the thread locker. After pulling the stock skid off I was also surprised to see just how heavy the stock skid was, about 42 lbs according to Nth.
Since my skid was used it had the powder coat scraped off in a few places, so I hit it with a few coats of anti-rust Krylon black paint, this way it will also match my future Rokmen skid.
Stock skid vs new:
Stock:
Nth skid, note that because of the design it has points within the skid that are higher than the frame rail mounts, this does not allow the skid to lay flat like a traditional skid, so this comparison favors the stock skid. You can tell the sides of the Nth are still nearly 1" off the ground:
Next major step was to dimple the floor of the tub with the special tool. Well I purchased my skid used, and it came 'special tool free'. The instructions refer an included chart that has various combos of BLs and MMLs to reference to see if you will need to dimple the tub. With my 1.25" BL I figured (hoped) I was in the clear since I also did not have this chart. (While its likely not the best practice I later accidentally dimpled my Tube using the Tcase and a floor jack).
There is a Tcase linkage drop bracket (much like included with the JKS BL) for those that are not running BLs. But since I had a 1.25" BL the instructions said to skip the bracket installation.
Here is where things start getting a little 'creative'. The locker pumps are currently located behind the Tcase in the stock configuration. They need to be moved in front of the bulk of the Tcase, positioned along side the front driveshaft. This is an excellent location as they are still completely protected by the skid, but requires a little reworking of the wiring and air lines and modification of the bracket.
The locker pumps can be seen in their stock location in the upper right:
One side of the locker pump bracket has a 90 degree bend in it. To mount to the new location the same bolt holes will be used but the 90 degree bend must be straitened to 0 degrees, or no bend at all. There is a reinforcing arch in the bend that must be cut in order to straiten the bracket. An angle grinder makes extremely short work of this task.
Straitened locker pump bracket, with arch cut:
The shovel:
Nth skid unmounted:
Stock skid vs new:
Stock:
