93 & 95 should be the same…provided they both are manual or auto as the case may be.
93 was a bit of a learning year for the ZJ
Thanks that's what I was thinking just don't want to get it and it won't work in mine it all matches up just numbers aren't same93 & 95 should be the same…provided they both are manual or auto as the case may be.
This is all there isThe serial number isn't going to be the same, that's more like a fingerprint for that device. The model or module number is what needs to match up, or be a substitue for.
It's dead completely has nothing but I did notice that the ground was not connected when I pulled it out it did work till I my Vic started strobing white light and killed radio Vic and heater replaced radio and Vic now just heater controller out tested wiring it's getting electricity to it so now I'm replacing it think I might ground old one to see if that helps but it does have a burnt smell to itare you by chance replacing the heater control because the fan switch is not working? If so, I had to install a better ground wire from control to provide a better ground and that solved the problem. I got this advice from a jeep mechanic friend of mine who saw this on a few other vehicles....Best Jim
