1 - 20 of 122 Posts
This thread will tell you what trucks you can take shocks from and put on the YJ for a 4inch lift. This is a great way to stay on budget and have shocks that are the right length for your lift.
I started looking around jeep forum last week trying to find this very thread but couldnt so I did all the reserch and figured Id post it on here. The reason I went with truck shocks is because I had bought stock yj shocks from autozone a couple of months eailer and then I decided I wanted to do and lift and I didnt want to weast the money I had just spent on my shocks. Autozone agreed to swap them out, so I went and did the reaserch and figure out what shocks i needed then I swapped them.
For those who cant just swap your old shocks out this is still the cheaper way to go with out sacrificing shock performance ALL 4 SHOCKS COST ABOUT 85$ all together.
Here's the info and a few pictures.
Based on this web site http://www.monroe.com/assets/downloads/english/08_MountingLengthSheet.pdf
I have found that 1997 ford f150 rear shocks for the front on the yj are just about perfect and mounting is almost exactly the same, but ill be using Gabiral shocks so the lengths very a little from the monroes. I especially like the fact that the f150 shock has 12.03 inches of travel!
YJ stock specs: Compressed 14.5 in
Extended 24.375 in
Travel 9.8 in
(Gabriel Pro Guard Shocks)
97 F150 specs: Compressed 16.3 in
Extended 28.3 in
Travel 12.03 in
Part number #61612
Here is what I found for the rear. 1974 ford F250 shocks will mount up perfectly and have the exact lengths I want as well.
YJ stock specs: Compressed 11.8 in
Extended 18.3 in
Travel 6.5 in
(Gabriel Guardian Shocks)
74 F250 specs: Compressed 13.8 in
Extended 23.2 in
Travel 9.3 in
Part number #82147
I received the shocks the next day and they mounted up perfectly just like the web site's measurements said. Ive been driving them around for a couple days and I have absolutely no complaints. This beats the heck out of spending 200$ on aftermarket shocks. I highly recommend this if your on a tight budget like me. Thanks for reading.
First picture is compressed and extended front shocks and second picture is the rear shocks.
Electric Chair Operator
Yep, I've been doing that for years & years. :)
I was raised by white trash in the '60's in Los Angeles, CA and know all too well what its like to be on a budget. :laugh:
I did the same thing and I knew what I was getting for the price. The shocks ride fine on the road for me but sometimes I feel they are too soft on the trail. I'm thinking we just put those shocks you mentioned on my Buddies CJ-7. He put Ford F250 shock towers on because his other ones just didn't have the travel. His is a trail rig and on the last ride he broke all but one shock mount so this was a big improvement.
If I can find a decent set of used Bilstein's I'll try to get them in the future though. Right now I need a new steering linkage.
Great info! The only problem I see is when you flex it being all the shocks have 2 inch less compressed length it would limit your up travel when on uneven ground. Might not be that big of deal but just a thought. Do you have any pics of it flexing to see how it sucks up the down tire?
Yeah right now i just have them under my jeep with my 2in booms but this friday im starting my s10 bastard pack lift and hopefully I end up with about 4in total lift including the booms.
With 2" boom shackles. 4" total including shackle. Sounds right to me with sua. If he was SOA it would be crazy. 5.5 stock then add 2 for the booms and 2 for the bastard.... That's 9.5" lift if he was SOA. So not needed haha.
Discussion Starter · #14 ·
Neither did i :rtft: :laugh:
i did a bastard pack for a buddy and all it did was not allow the springs to sag like they were it was back to stock height.
oh ok I got a little mixed up there, but yes now that the basterd pack is done im netting about 4 inches plus some in the back.
Discussion Starter · #16 ·
absolutely no problems flexing with the bastard pack and shocks. I did this just for you today. the edge is over 1 and a half foot right were its at and I could have gone even further but i was by myself and didn't want to tip. (im not very experienced with flexing.
Be careful on the rear shocks and make sure that the auto parts store gives you the ones with 2 eyelets and NOT the ones with the stud and one eyelet, or better off just ask for the ones for a 91 grand wagoner (same shock)
I have been fighting with the idiots at the auto parts for about a week now first off they had to special order them, and they where the ones with the studs. Then they reordered and I got 2 different shocks with the same part number on the boxes but the compression rate is different on them. Now I have to run to the next town tomorrow to get Hopefully the correct ones and finally get them installed.
The fronts do feel much better though. I would defiantly recommend extended brake lines, because mine where tight with the factory shocks and with the longer shocks I got 3 inches more drop in the front when flexing so the factory would have pulled or snapped.
absolutely no problems flexing with the bastard pack and shocks. I did this just for you today. the edge is over 2 foot right were its at and I could have gone even further but i was by myself and didn't want to tip. (im not very experienced with flexing.
Looks good Thanks
Discussion Starter · #19 ·
For the brake lines i just relocated them to the bottom of the frame, was super easy and gave me a ton on brake line to work with. Also didnt cost me a thing!:2thumbsup:
For those fronts (rears out of a f150), does it matter if its a 4WD or 2WD vehicle? Im trying to find a spreadsheet to tell me f150 shock sizes, but cant come up with anything (not the greatest researcher either :p).
Anyone know if what years the f150 rear shocks would work (having a tough time tracking down a specifically 1997)
1 - 20 of 122 Posts
