21 - 40 of 30683 Posts
RIP one good jeeper
I think the lines need to be redefined as to what is tech and what isn't. The question was where to buy something which is technically non tech along with asking how much the jeep is worth. But it could be construed as tech and I would answer it.
I really think we need another section along with /f12/ like a /f121/ directory where we can have dedicated Yj non tech where we get answers from Yj folks and not mixups from the tj crowd. Educated as they may be, they're not driving the same vehicle. I don't post about their jeeps value and expect them to not post about mine. If they were local it would be a toss up though.
Just to clarify, I was asking about the hydraulic line between the clutch master and internal slave cylinder and value of that line, not the value of the jeep itself.
RIP one good jeeper
I know. But the question was how much to buy it. Not what it does. I was making a suggestion for the entire section in this reform and in the process failed to also answer your question.
runtime error = 0
It is not well regulated now I doubt a new section would change that. Besides there are other areas of this forum for non tech or general tech. It should be self regulated by members. Mods can't do it all with as many posts as this place gets. It's not the mods fault people post in the wrong section. Its a full time job telling people they are off topic. A forum is its members. Stop answering the non tech and when you see non tech let the OP know. just my opinion on how to slow it down.
I didnt see a YJ General forum, so I figured this was a good spot. I could post in Wrangler General but that internal slave line is YJ specific I believe (uses a different fitting than external) since the external slaves started in 94.
Administrator
That's exactly what I had in mind. GD or Wrangler GD is not really correct, since it's YJ specific. We'll get it right and making sense eventually.
Just realized that the two links I put in the first post are lost now that we are on page two. Have to figure something out for that.
also part of the problem technical discussions sometimes really quickly turn non-technical and vise versa so that adds to the mayhem ... there is no real easy solution IMO
Administrator
Very true, but at least if the first post is a question or defiante tech it can wander from there.
There was a post the other day from a guy that was just "Hi, just bought a YJ and checking in" I really had to move it to GD but at the risk of discouraging him from participating. I'm hoping this area can be a home for that stuff.
The good news is none of this is a tatoo; it can be changed pretty easy.
Maybe I just need to adapt to it, but I currently do not see any feasible nor practical reasoning for forcing me to click more times just to find a thread that I and the rest of the YJ community like having quick access to.
I think its a great idea Bolty. The sticky section had become a bit obese. :D You know how any of us with a little time on here react to change initially. You've made it clear you are open to suggestion and trying this out for a bit. I suggested in the survey a while back that a YJ advanced tech be added. I thought it may weed out some of the weekly runs of common questions and eliminate sorting through non-YJ threads in the general advanced tech. Not sure it would be popular though considering how the general advanced creeps along most of the time.
Actually I think the thread "What did you do to your YJ today?" should be a sticky because technically it's a technical thread, but just a place for everyone to put their daily tweaks or changes they've done, rather than making a new thread for everything they've did (which is fine, as long as it's a writeup, how-to, or something along those lines, where the process of carrying out the modification might not be clear to people). It's nice having that thread at the top of the forum because it's in an easy to access and convenient place so we don't have to go dig for it.
Threads like "You know you own a YJ when..." or "What makes your YJ unique?" aren't really technical threads, but they do have to deal with the YJ model specifically, so I think it's great that we can have a simple thread such as this for quick access to them. Keeps the top of the board clean and organized and hides the chatter, but still lets us access those threads easily.
I'm also a tad surprised that 6-7 stickies are considered "too much." i've been to other forums (covering a varied range of subjects) in which it's not uncommon to see 14-20 stickied posts.
Additionally, the YJOTM threads are also not "technically" technical threads, either.
RIP one good jeeper
They're not technical at all but I begged and pleaded that they be stickied at one point so that that wouldn't be lost in the abyss of Yj tech and then we would have only one contestant instead of six.
Even more of a reason to have a Yj non tech section. Should we all send Keith a PM? :nono: I'm pretty sure it would get me banned for the idea. How about a thread in the announcements and comments section?
EDIT: thread started
http://www.jeepforum.com/forum/f6/any-chance-yj-non-tech-section-1391228/#post13843251
runtime error = 0
The threads you reference are general chat threads. They are not technical. Any questions asked there that are technical would get more attention as their own posts. In my opinion the way you look at the forum is why we are having trouble with so much non tech. YJ tech is not an area to socialize and discuss that someone did today. You want to socialize. I don't mean this as anything negative against you only as a good example of why its hard to regulate. You either draw a line in that sand or you let things run amuck. There is nothing wrong with structure.
and stickies are the devil. Keep as few as possible.
I agree with Xpress that the "what you did..." thread should be a sticky since its nothing but little modifications done to our yjs on a daily basis not worthy of starting its own thread to clutter up and drop more important threads down. While I agree with poke that the "You know you own a..." is definitely a chit chat type of thread and doesnt need to be a sticky.
Why are stickys the devil? Dont like to be organized and convenient? I can see too much of a good thing can be bad but I dont feel that it was over board, maybe just drop a couple of them. Im sure Ill get used to the new setup, but for now it seems like more clicking and searching.
All that happened is 2 threads became one in this new thread. What did it really change? I bet the 2 that were put in the first post on this thread will be ignored as this thread just takes them over.
Well yes, "You know you own a YJ when..." and "What makes your YJ unique?" are general chit chat threads, but the "What did you do to your YJ today?" thread is more technical than it is a general chit chat thread. Why let it run amuck down in the non stickied sections of the forum? That's unecessary and it crowds up the forum more because it's a popular forum. Nobody wants that thread being constantly bumped to the top of the non sticky section, because it's going to force threads that need attention down south where they won't get seen. Keeping it sticking is a good idea. The other 2 threads could probably be moved to GD as they are just that, General Discussion threads.
.YJ tech is not an area to socialize and discuss that someone did today.
What about all of the build threads then? Perhaps they should be moved to GD too, because 90% of the thread is socialization and discussing what people did to their Jeeps on that particular day.
Or what about threads like the Track Bar delete threads? People talk about what they did that day to improve their suspension all the time, daily.
That is why a thread like "What did you do to your YJ today?" is absolutely perfect to have stickied to the top of this forum in particular because it cuts the crap out of the rest of the forum.
Administrator
I think that's probably true. Need a better solution for those, see below.
The "what did I do today" thread gets a fair amount of posts so it probably should be put back as its own stickie. Everyone seems to like the idea of a Chat thread so that should probably stay as is then maybe one more container added for the other non-tech posts.
The reality is that the definition of "tech" is pretty loose. Essentially anything that requires a tool of any kind or sandpaper is tech.
The problem with stickies in general is if there are too many then they are no longer special or receive any extra attention. Plus as I mentioned earlier the entire front page was taken up by stickies at one point leaving room for only about 3-4 regular threads before having to go to page 2.
A few of the mod threads like seats, junkyard mods and wheels and tires have only had a post or two in a month but they are valuable enough in my opinion to have grouped at the top of the page in the Mod super thread.
Lets get some more feedback over the rest of the day.
Right now I'm thinking this for the stickies, in no particular order
Chat thread
YJ Mods
YJOTM
FAQ
RULES
what I did today
Then maybe one more as a container for the non tech stuff that is YJ specific.
Thoughts.
