So I have searched the internet until my eyes started bleeding over this:
How does one test - and I mean definitively test - an IAC and a TPS on a 1999 (late model) 4.0L - those threads on renix 4.0L's are all wrong for me - not the right wire count, different sensors, etc.
I don't want to throw parts at the car, and id rather not go to the junk yard to pick up $2 sensors in the hopes they are good and I can use them to "test" the system. I could start swapping stuff with my brother's 4.0 but he actually has a drivability issue of his own hahaha.
I have a multi-meter, and the more than basic know-how (used to turn wrenches for a living) - but cant seem to find values or anything like that for either sensor. TPS I wish I had an oscilloscope for - but I can move it slow enough to check voltage for dead spots I suppose - is the only way process of elimination by confirming all other sensors that are possible culprits are good?
Or perhaps someone has the exact issue I have - since there seem to be an infinite variety of issues:
So, the basic issue is hunting idle - it has been getting more frequent and increasingly rough over the last few weeks. It doesn't seem to matter if the engine is cold or hot, and it doesn't stall. Normal idle for me is 750, this dips to maybe 550 and recoups and overcompensates to maybe 800. In neutral the issue all but goes away, and if I catch the idle when it dips as I accelerate it will result in a momentary stumble, but only if I accelerate at the low point of the idle. It *almost* seems like a front O2 sensor, with the exception that a) it doesn't stall and b) its not as erratic. I've had no sensors changed yet - I have cleaned the IAC and throttle body somewhat recently. The funny thing is, the idle doesn't move that much yet the result is profound. A lot of vibration at stoplights. No codes - no light, and none on the tool. Not really hard to start either - no long crank, no start then stall.
