Edit on 7-16-17 - I removed some of the bad inline Photobucket links and attached the images directly to the thread. The attached images should be in the same order, but will be a little more difficult than the inline images. Also, there's a limit to the number of attached images (ten), so some images are missing. Post up in the thread if you want to see a missing image or if something isn't clear, and I'll add details/pictures as needed.
I thought I'd document progress on my 8.8 swap. Nothing revolutionary is going on here - I'm following in many other's footsteps. There's a bunch of great links to other threads in the Appendix - Part 9
Steps:
The first 9 posts of this thread are:
Part 1: Introduction and Acquiring Parts (completed Aug 2013)
Part 2: Disassembly, Welding Tubes, Cutting and Painting (completed Sept 2013)
Part 3: Parking Brakes, Bearings, Seals, Reinstall Axles, Solid Diff Cover, Calipers and Rotors (completed Sept 2013)
Part 4: Tummy Tuck and MORE Shock Brackets (completed Oct 2013)
Part 5: Setup 8.8 in Jeep, Finish Weld Perches and Shock Mounts and Run Brake Lines (Completed Oct 2013)
Part 6: Exhaust System Mods, Final Axle Install and Parking Brake Cables (Completed Nov 2013)
Part 7: Rear Driveshaft (completed Oct 2013)
Part 8: Skid Plate Mods and Final Pictures (Completed Nov 2013)
Part 9: Conclusion, Future Plans, Appendix (Completed Nov 2013
Update on 11-20-2013:
I'm adding a couple of more projects, since they are related to increasing ground clearance.
Part 10: 1" Gas Tank Lift (Completed Nov 2013)
Part 11: TJ Rear Flares (originally planned for Dec 2012 as part of this build, then moved to this thread instead: StanF Rocker Guards and TJ Flares)
Part 12 BONUS - Added Detail on Parts Options for your 8.8 Swap: StanF Parts Detail
Part 1 - Introduction and Acquiring Parts
Reason for Swap:
My goal is to have a nice rig that I can drive to the trails and drive back (not trailer back!). In particular, I wanted a "bulletproof" rear end that would always get me home, and potentially accommodate larger tires in the future. (I'm on 32" tires at the moment)
Honestly, I would have preferred a Dana 44, since they were stock in some Jeeps (just not my YJ!). But Dana 44s are hard to find in my area and expensive. I chose the 8.8 because (in no particular order):
1) They are readily available in the gear ratio that I need (4.10)
2) Cost is reasonable
3) There's a wealth of information online about performing this swap
4) Swap parts and kits are readily available
5) Uses the same 5 on 4.5" Stud spacing as my Dana 35, so no wheel changes
6) Disc brake upgrade for free! (just choose the right Explorer as a donor 1995-2001)
7) Ground clearance is about the same as the Dana 35
I see three minor downsides:
1) The 8.8 is a little more narrow than the Dana 35 - about 5/8" on each side. I'm not concerned, but you could use wheel spacers ($$) to correct this if it bothers you.
2) I really hate putting a Ford part into my Jeep
3) The pumpkin is off-center a bit
My existing Dana 35 is a weak point, and adding a locker would make it even less reliable. A previous owner evidently had issues with my Dana 35 because of the marks on the carrier:
Extras:
While I am doing the 8.8 swap, I am also doing several other "extras". They are things that won't be noticeable to the untrained eye, but that can improve the offroad capability:
- Tummy Tuck with a Barnes Flat Skid Plate. I am doing this for more ground clearance. It's included as part of the 8.8 swap, so I can get the pinion angle set right.
- MORE Shock Extensions - I'm installing these so that I can mount the shock brackets higher on the axle for more ground clearance and fewer snags
- Dynatrac U-bolt Flip Kit - for more ground clearance and fewer snags
Luckily, the Jeep isn't a DD, so I can take my time with all these mods.
Find an 8.8:
To the local pull-a-part junkyard, we go:
I found it was best to look at the door tag to figure out the axle ratio.
This is a sample image - not the one from my 8.8 donor
The "45" code equates to an open differential with 3.55 gears.
For those few Explorers without doors, I crawled under and looked at the tag on the pumpkin.
Here's a neat cheat sheet to take with you to the yard:
It took me three trips to get an axle...
The first trip (to a junkyard up north, 45 miles away) was a waste - they didn't have any 4.10 rear ends.
The second yard (80 miles south of the other yard!) had two of them. After screwing around with rusted bolts for way too long, we ran out of patience, and the 107 degree heat chased us away before we got one out of the Explorer. That Explorer wasn't from Texas, as it was way too rusty - every bolt was a serious PITA.
Finally a month later, I found this beauty with 4.10 LSD (the only one with in the yard).
I'm not thrilled with 180k miles, but it's not like I had a bunch of choices. It was a limited slip axle, which was fine. Since I have plans to install a locker, I wasn't real concerned if my 8.8 was limited slip (LSD) or open. It came out pretty easy - no rust at all on it. I don't think we even cracked open the PB Blaster.
The regular price for a rear end was $125, but they charged me a $25 core fee, and extra for the parking brake cable and calipers, and, of course, sales tax. At first, they tried to charge me for the rotors, but they weren't any good. I got a 1310 yolk out of an older Explorer, and it was included in the price.
Even though I wasn't planning to use them, I grabbed the U-bolts. Unfortunately, I didn't get the U-bolt plates. In hindsight, I wish I had gotten the plates too. Others have cutoff and used the Explorer shock mounts instead of buying new ones. It would be better to have them and not use them.
$200 later, it was sitting in my garage. It stayed there for about a month while I bought the other parts for the swap.
Parts:
First, let me say that there are MANY companies that make individual 8.8 Swap Parts and complete kits. Some of the places are MORE (Mountain Off Road Enterprise), Ruff Stuff, East Coast Gear Supply, Barnes 4x4, etc. Look around and price the stuff that you need/want. I believe that all the kits will work, but some may be better suited to your build (or budget!) than others.
Since I was using Dynatrac's Ubolt Flip Kit, I didn't need U-bolts, so buying a complete kit didn't make sense. I would have just ended up spending more $$ on extra parts. So I pieced together my parts from several suppliers.
The cost of all this stuff adds up fast. I bought more than I needed to, and I wish I had more time to fab stuff myself. One note...I went with all new brake components - I just didn't want to take a chance on anything not being perfectly right. It added quite a bit to the cost, but it was worth it to me for peace of mind.
8.8 from Junkyard $200
1310 Yoke Adapter $0 (included with 8.8)
Solid Diff Cover $82 (https://www.solidaxle.com/)
Parking Brake Cables $77 (East Coast Gear Supply) (edit on 11-6-2013 - beware of issues - see Part 6)
Brake Line Kit $67 (East Coast Gear Supply) (edit on 10-30-2013 - not recommended - see Part 5)
Parking Brake Shoes $20 (local auto parts store)
Parking Brake Hardware Kit $20 (local auto parts store)
Rotors x 2 $60 (local)
Mopar Leaf Spring Perches P4120074 $13 (JEGS - http://www.jegs.com/i/Mopar+Performance/312/P4120074/10002/-1?CAWELAID=1710617200&catargetid=1784155608&cadevice=c&&cagpspn=pla&gclid=CNqUnoisj7kCFenm7AodmGgAuw) (edit on 10-30-2013 - not recommended - see Part 4)
Shock Mounts $22 (Barnes4x4 http://www.barnes4wd.com/Bent-Tube-Shock-Bracket-Pair_p_76.html)
MORE Upper Shock Mount Extensions - $100 (http://www.mountainoffroad.com/_e/Shock_Mounts/product/9950/9950_Rear_Upper_Shock_Mounts_87_95_YJs.htm)
Dynatrac U Bolt Flip Kit - $215 (http://www.knowwhere2jeep.com/dynatrac-rear-axle-u-bolt-flip-kit-2-5-spring.html)
Set of Calipers/Pads - $85 (Rock Auto)
Brake Fluid $5
Gear Oil $13
Vent Hose $5
Friction Modifier $5
Axle Seals and Bearing Kit $28 (eBay - great price!)
Disc Brake Align Kit $6 (Rock Auto) - these are the four little tracks that the disc pads ride on
Paint, Cutoff Wheels, Grinding Wheels, Rags, etc. - $30 or so
Rear Lift Shackles/Bushings - $70
Sell Dana 35, 4.10 Gears and Solid Cover - minus $300 est
I'm up to $1133 in parts, if I added right!
About $300 of this is directly related to the U-bolt flip and Upper Shock Mounts, so it's probably about $750 for the axle itself. That is offset by selling my Dana 35, so my direct upgrade cost for the 8.8 is about $500 and a bunch of labor!
I didn't add in the Tummy Tuck components or rear driveshaft, as they aren't directly related to the 8.8 swap.
East Coast Gear Supply has a bunch of 8.8 Swap Parts, as well as complete bolt-in axle assemblies, if you want to take the easy way out:
http://eastcoastgearsupply.com/c-130046-axle-swap-parts-ford-8-8-parts.html
Edit on 2-7-2014:
A note on the 1310 Yoke Adapter...earlier Explorers with drum brakes - 1991 to 1994 came with 1310 driveshafts and yokes. The most cost-effective way to get this yoke is to take it off an older Explorer while you are at the junkyard pulling the axle out of the later Explorer. My local Pull-a-Part charges $7 for the yoke.
Edit on 2-7-2014:
A note on the Solid Diff Cover:
I find the Solid Diff Cover to be one of the best values. It's very heavy and beefy, and even comes with a tube of RTV. It's about $75-80 with shipping, which is about half what other similar covers cost. Highly recommended!
Here's a few pictures of all the new axle parts:
Next Step is Prepping the Axle
Steps:
Reason for Swap:
Extras:
Find an 8.8:
Parts:
Brake Fluid $5
Gear Oil $13
Vent Hose $5
Edit on 2-7-2014:
Edit on 2-7-2014:
