Hahahaha. 44/9" is something I'm always thinking about.
Hahahaha. 44/9" is something I'm always thinking about.Sack up and build a 44. Then wish you built a 60. Wanna buy a built 44?![]()
I don't want to know lol. But it's not as bad as I thought. My buddy had a flat skid in his TJ, which is basically just a big piece of plate and it weighs 60 pounds. I can't imagine mine being much more if not any more than that. I'm ditching the wet carpet so it will off set it lol. Plus, as long as I keep the heavy weight low, it doesn't bother me as bad...alexrule123 said:Looks good but my god how much does that thing weight!?
Yeah, I don't trust those for hard wheeling. I'm going to run bolts through the sides of the frame too. Instead of counter sunk bolts, I think I'll get some of the bolt protectors from ballistic fab.Timo_90xj said:At least all that weight is belowe your COG point, so it'll help keep the rubber side down
Looks good, but I'd worry a little about the mounting bolts below the frame.. I'd use countersunk bolts like I mentioned, I'm pretty damn sure you'll rip those off at some point.
Thanks! And I will soon! Bring your XJ to Crozet!Looks awesome and very well done! Now get to scraping it over all them big *** rocks you cruise over and let us know how great it is!! Lol...my cross member is starting to look like your factory one, and I don't do near the amount of hardcore rocks you do!!
Thanks man! Acutally, I've never had an issue with those. I figured I would, but they haven't stopped me yet!Looks good!..now start skinning those rocker support legs so you can slide over the rocks even better and not get hung up on 'em :thumbsup:
Yup, this is one of the single best upgrades for the TC linkage. I've never really understood what's the point behind that multiple- joint thingy that is under there.. It should either be cable actuated, or a single rod like yours is now. The heims allow for enough articulation between engine-tranny-tc-package and unibody on the bumps to not cause any problems. I friend of mine had constant problems with his XJ popping out of 4lo, replaced with two heim joints and all- thread and as far as I know not once has it popped out of 4lo after that! :thumbsup:Built a blingin' transfercase linkage out of 7/16" heims and some threaded stock. Had to flip the lever on the xfer case, cut it in half and put a 45 degree angle on it, and then welded it back together. Shifts a hell of a lot better and actually feels like it "clicks" into 4 hi and 4 low. Doesn't feel mushy anymore...
