Nice work! Can't wait to see how your plan turns out, I've got to do something for mine.
The exhaust actually is going to work I think. My exhaust has already self clearanced itself into my floor board. If it is too tight, I'll massage the floor or notch the crossmember. As far as mounting, for the time being I'm going to use the stock mounting holes just to get it on there. As you can see, the metal sticks out long that the frame rails are. I'm going to fold that metal up around the frame to "hug" it and then run mounting points through the frame. I'm sure the bottom factory bolts won't last long!Timo_90xj said:What are you gonna do with the exhaust? Run a more compact- sized cat and muffler? It's pretty damn tight fight to get a muffler and cat tucked into a flat belly without cutting the floorboards..Flat belly, low stance and large tires is the way to go IMO so you're on the right track
I'm guessing you don't even need to notch the tranny x-member for front DS with the clocked TC? How are you going to mount this thing, weld in an extra support plate to the "ears" and add vertical mounts with crush sleeves through the unibody? Sure looks like a good starting point :thumbsup:
Should work that way..As far as mounting, for the time being I'm going to use the stock mounting holes just to get it on there. As you can see, the metal sticks out long that the frame rails are. I'm going to fold that metal up around the frame to "hug" it and then run mounting points through the frame. I'm sure the bottom factory bolts won't last long!
Thanks. No long arms on this XJ. I can make short arms work just as well. I'll also have more clearance and making what I'd want (mid arm 3 link) is way more work than I want to put into it right now.I like that : ) .. while your there... should put some long arms on : )
Thanks dude!Nice work! Can't wait to see how your plan turns out, I've got to do something for mine.
Is it legal to be a jig pimp? :rofl:You should rent that jig out when you're done. 5 bucks to your paypal and mail it to the next guy.
I've seen a thread where a reamer just travels around from one person to the next for people going to 1T TRE.
I've thought about clocking my t-case if I decide to pull it for my SYE, but 45 bucks for a jig I could make for myself seems spendy.
I have an old stock x-member that looks close to yours.
That sounds like a great idea! The studs in the frame, do they just twist out? I didn't want to try it to find out I couldn't put another bolt in there.Should work that way..
If I may suggest, you might want to use 10mm countersunk hex-head bolts (class 10.9 or 12.9 so they are hard stuff), then weld another 3/16 plate to the bottom of the "ears" and drill large enough holes where the mounting bolts go through - so large that the head just goes through the hole as well.
This way you will have countersunk bolts, and the additional 3/16" plate both gives you added strength on the key area, and also gives you just that much clearance over the bolt heads so they don't get smashed to rocks as easily. I did the x-member on my ZJ this way, and I've scraped the heck out of it on rocks and so far zero marks on the bolt heads :thumbsup:
Don't let the man keep you down!Is it legal to be a jig pimp? :rofl:
Yes the twist out, the double nut technique works very well.... wait, what? Also, if you look in front of the factory cross member mounts there is a sleeved hole on each side, you can tap that and use that for a 3rd bolt to hold the cross member on.That sounds like a great idea! The studs in the frame, do they just twist out? I didn't want to try it to find out I couldn't put another bolt in there.
Actually, I have never seen those! Might actually order a few....I'm sure you've seen these type of things before, but it's an alternative to the 3/8s plate idea. Plate would probably be cheaper anyway.
https://www.ballisticfabrication.com/mobile/product.asp?itemid=1684
Thanks man. Good info. I'll replace those studs with new bolts.Yes the twist out, the double nut technique works very well.... wait, what? Also, if you look in front of the factory cross member mounts there is a sleeved hole on each side, you can tap that and use that for a 3rd bolt to hold the cross member on.
3 links are really nice for sureThanks. No long arms on this XJ. I can make short arms work just as well. I'll also have more clearance and making what I'd want (mid arm 3 link) is way more work than I want to put into it right now.
I've been thinking about the idea of fabbing high clearance axle brackets, that way the lower arms would basically be flat up to around 3" of lift or so.. With a little extended wheelbase and adjustable arms that should work ok.Thanks. No long arms on this XJ. I can make short arms work just as well. I'll also have more clearance and making what I'd want (mid arm 3 link) is way more work than I want to put into it right now.
I've thrown this idea around a good bit. I just can't justify putting that much work into a Dana 30!I've been thinking about the idea of fabbing high clearance axle brackets, that way the lower arms would basically be flat up to around 3" of lift or so.. With a little extended wheelbase and adjustable arms that should work ok.
There are a couple issues though; you'd need to rebuild the upper mounts as well, basically needing to fab a truss (possible fitment issues at full bump). Another problem is the added leverage because of the mounts being fairly far behind axle centerline. Then again, with OTK steering and flat arms the on- road handling should be great, and axle articulation + obstacle climbing abilities when wheeling really good as well.
3- link mid arms or long arms would be great, but they sure are a lot of work.. but so would be high clearance brackets![]()
I'm so stuck on the fence on this.I'm a college student so I don't make all kinds of money. I keep telling myself to stay on 35's until I'm done with school. If I did a 44 swap, I'd then want a 9" or 60 and 37's, do a mid arm 3link, blah blah blah......... :laugh:Kinda thinking the same waySwap in a D44?
I'd do that, if there weren't the stupid laws here in Finland that prevents me from deleting abs- brakes and running wider track axles..
I'll stay on 35's until I'm done with school. I can afford 30 and 8.25 parts all day long. :laugh:Do you have the cash $$$ for 37 and a set of axles? Or to break stuff? If not stay on 35s
