Price | $315 |
Rating | 3 |
Pros | - Extended fender height is great
- Cost is significantly less than other flare options of this type
- Easily paintable (although that is almost the cost of the flares themselves, be aware) |
Cons | Cons:
- Install
- Install
- Install |
Recommended | no |
Comments: Bolt On Install? Don't Believe It...
After 6 hours I just completed the 1-2 hour install time estimated for these flares - and I'm actually pretty mechanically inclined.
I received the flares, they were packaged well. I took them out and did rough line ups on my Jeep and they looked pretty good. Sent them off for painting and they came back matching to the Jeep like it came from the factory. I'm pretty happy up to this point.
The first step is to intall the side marker lights. I followed all the instructions to a T, and most of it was fairly straightforward. The last part was where I started encountering troubles, and it was a sign of things to come. The side marker lights screw into what they call 'posts' - basically they are two raised bumps of excess polyurethane - and they are not predrilled, nor can you easily predrill them given their recessed location. The side marker backer is supposed to simply screw in, but the posts were so hard that was nearly impossible. And to boot the predrilled holes on the backer didn't line up with the posts - this was to be a continued issue going forward. After much elbow grease I finally got the screws to thread and got the lights installed to the flare. So now I think the hard part is over. Not even close as it turns out.
I go to put the first rear flare on, bolts on relatively well - this lulled me into a false sense of security as his brothers had no intention of going on without a fight. The next rear didn't line up at all. I had to install one screw as an achor, then flex and bend every other screw hole to get it to align. I'm hoping that continued torque pressure won't cause me issues in the future.
The fronts were even more ridiculous. While polyurethane is a very durable material, it is also evidently very difficult to get it to stay in the intended form after it is cured. The inner side of the flare not only didn't line up on the screw holes again, but actually curled away from the fender sheet metal - so much so that I couldn't get the screws to thread. After numerous unsuccessful attempts I finally got a bottle jack to push the flare up into position and hold it, and then vice grips to pull the flare inside closer to the sheet metal. And I had to do this for almost every single screw hole. When it was finally on I again thought the worst was over so I completed the wiring of the side marker lights per instructions (and confirming the proper wiring on the Jeep Factory Service Manual). Turned on the lights. Nothing. Front marker lights are lit no issue, nothing on the flare marker lights. I disconnect the wires and validate there is juice coming to the marker light - there is. After the hassle of getting the 3 flares on to this point I have 0 desire to a) remove the flare b) remove the side marker lamp c) dissassemble the side marker lamp (which is now sealed with silicone sealant per the instructions). I simply couldn't justify another 1-2 hours on that field trip.
The last flare was just like the one above only twice as bad on the alignment. Even with the bottle jack and vice grips it refused to line up. I spent at least 15 minutes per hole coaxing it into position before it roughly fit. Didn;t even bother trying the side marker lamp - just taped it up and called it a day.
Bolt on application? Only if you consider walking across the state of Texas as an evening stroll. :thumbdown:
Things I would recommend if you choose to buy:
1) Take the side marker lamps, wire them, and test them inside the existing Jeep fender first. Only after they light there should you assemble, seal, and integrate them into the flare fully
2) Don't underestimate the time. Mine was 3-4 times what I expected
3) Be ready (and have the tools) to adjust and align these on the fly - I sincerely doubt other will line up that much better.
