21 - 40 of 45 Posts
Price $250
Rating 4
Recommended yes
Comments: THEY ACTUALLY THE STEP DOWN SERIES FOR THE JK. I LOVE EM CAUSE THEY HAVE A STOCK LOOK BUT ARE JUST WIDE ENOUGH TO COVER A 13.50 WIDE TIRE W. A 1.5" SPIDER TRAX SPACER.LOVE EM!!!
Rating 4
Pros Look good and went on easy
Recommended yes
Comments: I got them because I did not want the weight of full tube flares in the rear but I wanted something to match my TNT fenders up front. They look like they are a matched set. They would have bolted on if my tub was straight.
Price $390
Pros Good look, easy to install
Cons Marker lights are a pain
Recommended yes
Comments: I like the look of these flares. They are easy to install and go nice with my Rokmen Strykers. If you are not ready to do true flat fenders I would take a good look at these flares.
Price $550
Pros great looks, paintable, great looks in the mud.
Cons pricey.
Recommended yes
Comments: look better than tube fenders that everyone else runs.
Price $352.99
Pros allows more tire clearance without adding more lift or trimming...
Cons lights are a pain, had to redrill a couple holes to custom fit to my rocker guards....
Recommended yes
Comments: I got a great deal from 4wd.com and had them in less than a week. they look great and allow you to not only fit 35's with only 3" of lift but they allow you to wheel 35's without the worry of rubbing... BTW, I have the 4" flares not the 6"
Price $480
Pros Great looking and easy to install
Cons None yet
Recommended yes
Comments: Makes the Jeep look like it is lifted higher that it actually is and gives a great stance and tire clearance. Painting the Jeep in a week or so and will let you know how they hold paint
Price $375
Pros Good looks and CLEARANCE
Cons Front flares sagged...expensive.
Recommended yes
Comments: Look great and you get a ton of clearance for bigger tires...easy! The front flares started to sag and had to put mounts under them to make them look right. The one other con is that there a little pricey.
Price $400
Rating 2
Pros look good at first ,easy install
Cons had a set on my last yj and they started to droop and bend in the arizona heat, only the f5ront ones the back ones kept shape, expected more or better quality for the price i paid but found out $400 onley gets you substandard quality
Recommended no
Comments: would not recomend, substandard quality,better off getting tube fenders with 3" flare instead of wasting your time with these as they dont hold up to heat so if you wheel in a hot state such as az you will not be happy with them unless you like drooping and sagging fender flares that are suppose to be straight
Price $200
Pros gain a true wheel well spacing. Give a rugged look but leaves room for flex w/out rub on flares.
Cons tires still stick out pretty far. but that's what inspection tires are for ;-)
Recommended yes
Comments: Made out of a solid material. They have held up great so far. I have no major complaints.
Price $400
Pros tire clearance, looks, bolt on easy
Cons hand cut, lights
Recommended yes
Comments: I purchased these for my wifes TJ in the 4 inch variety. Lets just say for $00 i expected more. The lights were a pain in the you know what to install and the clips for the wires were junk. they are clearly hand cut so not perfest and needed to and a lil trimmed off and sanded down for perfection. We should have just went with front tubes for the hassle.
Price $500
Rating 5
Pros Excellent fit, flexible, extra clearance, built in marker lights
Cons None
Recommended yes
Comments: 6" on a TJ with D44's front and rear. 12.5" wide tires. Perfect coverage to abide by the law. I can't recommend these enough. They look great, they provide extra "stuffing" room, they're flexible, have built in marker lights, fit well and easily.
The only one thing I'd like to see Xenon do is to make them like a hi-line fender and not have the 45* angle at the front. That way you can have a slightly better approach angle. But hey, that's just me.
Good job Craig! :highfive:
Price $375
Pros Love the openness of the wheel wells now.
Cons Came missing hardware, one flare wasn't drilled and was rather warped.
Recommended yes
Comments: I love the look of the flares, and the functionality of the more open wheel wells is great. Plus the added tire coverage keeps tire spray more contained. When I received them though, they were missing hardware, one flare was not drilled at all and another was very warped and needed heat to be properly shaped.
Price $340
Rating 3
Pros Cheaper than tube flares/fenders and provide extra tire clearance.
Cons Haven't found any yet except that they are not Metalcloak fenders/flares.
Recommended yes
Comments: I bought these for my YJ because I was adding bigger tires and needed the clearance. Were money no object, I would have preferred to go with Metalcloak flares. However, these will do the job nicely and I still like the look of them. Time will tell how well they hold up. I plan on leaving them black rather than painting them.
Price $340
Rating 3
Pros inexpensive compared to metal tube fenders (when you consider cost of all four). Pretty much direct bolt on. Better tire clearance. Aggressive look. Flexible.
Cons Too high priced considering fair to poor fit and finish. Look like they will scuff easily - should be matte finish instead of smooth/gloss. Side markers are a joke - fenders are not drilled for them and are not easy to drill, you have to supply wire and connector. Instructions are not very good. We'll see how they hold up over time.
Recommended yes
Comments: I gave this product a YES recommendation only because there are not really any comparable options out there for YJ owners without spending more $$ and/or having to do a little more fabrication/modification of fender wells, etc. Xenon gives you most of the parts for the side marker lamps (really cheesy) but you still have to assemble them, supply a length of wire and a connector, and you have to drill the posts in the fender wells to screw them in. For what you pay for these fenders, they should provide completely assembled side marker lamps, with proper wiring, and drilled the mounting posts in the flares. These posts are difficult to drill and I don't know what remedy you have should you screw one up. Finish of the flares is sub-par. Most of the flashing from the molding process is ground off on the inside of the flares but the openings for the side marker lamps are not real clean - I took an exacto knife to mine and improved them considerably. Again, for the price, you shouldn't have to do this. I did not have any trouble fitting my fenders to the jeep and the holes all lines up pretty well. There is a little room for adjustment and the flares can be flexed pretty well into position before you tighten them down. The lower most holes on the rear flares are the only ones not even close to the original holes - I'm guessing they are drilled this way (further out) so that those with TJ fender openings can trim the inside of the flares and mount them. For stock yj mounting, I just drilled new holes where needed and no problem. I really wanted Metalcloak flares and, if the Xenons (which really do all I need for now) last me until I can afford to splurge and get those, I'll be happy enough with them.
Price $435
Pros Great look, cover my 12.5 wide tires. Very functional.
Cons Running light installation not good
Recommended yes
Comments: These 6 inch flat style fender flares do what they are designed to do quite well. For the most part they seem to be well built and were relatively easy to install using factory hardware. I did feel that the running light mounting set up is pretty rinky-dink considering the price of these flares. The fact that the customer has to supply wire and electrical connectors seemed a little ghetto as well. In addition some of the screws used to mount the running lamps were missing from the kit. All in all the flairs are a nice looking, very functional addition to my jeep. I just think for the price the running light setup should be much nicer and the kit should include everything needed to complete the installation.
Price $375
Pros look great very strong plastic
Cons for the price disappointed with the included front fender turn signal
Recommended yes
Comments: Overall very happy with looks and added wheel clearance. Very disapointed with front turn signal thats included. First it is very cheap construction and poor design thats has use assembel the light and wire it, this could have easily been done by xenon. Second you have to drill holes into plastic to mount the light which should have been done by xenon. Finally very disapointed that I had to drill holes in the fender flares to mount them on the rear because two holes on them werent even close to the factory body holes. But overall I would def buy this product again just wanted to give honest opinion.
Price $360
Pros Flexible, durable material.
Cons Installation requires patience.
Recommended yes
Comments: After looking at the Bushwhacker and Smittybilt flares I decided to go with a set that isn't made out of hard plastic. The Xenons are a nice set of flares that do the job and won't crack. The tapered ends look nice but allow a lot of spray to kick up on the side of the jeep. Not a deal breaker but worthy to note. I suggest installing these on a warm, sunny day so that the flares are soft and pliable. Installation instructions are minimal, side markers can sometimes be a pain to screw down, no mounting hardware included.
21 - 40 of 45 Posts
